Turn signal location
I have a 987 2005 and cannot find the turn signal relay. Perhaps the 997 has the same location.
Above the fusebox is a relay cluster. I took out each relay but the turn signal did not stop working.
Anyone know where the 997 relay is?
Thank you
Thank you
I do not know the answer but for VWs and some other brands, the hazard button is used for the relay. I had a problem with the trunk signal in a VW (2001 MY) and replacing the hazard switch solved the issue.
Hopefully someone else on this forum might be able to answer this for you.
The relay is in a crazy place. Inside the instrument cluster and soldered in. I didn't swap it out.
Here is the image someone uploaded.
https://newhillgarage.files.wordpres...9/img_0672.jpg
This looks like the closest one that I could find.
https://www.ebay.com/itm/113750764844
