Intro: New-to-Me 997.2 (Also Rattle Help)
Skip to 15:20 for the process on how to remove the rear suspension.
well I pulled the woofer and front trim. Can’t find any loose bolts or deterioration of any bushings from strut mounts. See attached. Only strange thing I find is the front right strut mount is more inward to vehicle and the driver side is more outward. Car tracks straight and smooth tho.
it’s definitely a metal rattle/clunk on bumps only. Driving smooth highway, nothing. Sounds like bottoming out struts almost.
Congrats! The interior is Sand Beige. Did you replace the engine mounts? Shocks rarely made clunking noise. Shocks top mounts are usually the culprit. I think I read a while back about someone having a clunking noise when driving over bumps and it turn out to be the alcantara headliner support near the sunroof.
Could it be an aged Catalytic Converter with loose innards?? Have you got up close or used stethoscope?
