PCCM+ DIY Guide
#61
Update, I found another thread that said if you have a CD24, do this. Remove the double adapter and just plug the car's antenna straight into the upper output. No need to re pin connector.
#62
@RAudi Driver Nice find. I will keep that in mind if I hear about anyone else having trouble. I did the swapped ends on the cable and mine works perfectly but your solution makes sense too as long as the cable locking mechanism still works so the cable does not fall off on a bump.
Now to finding the Macan (Or 2016 era Boxter, Cayman or 911)) steering wheel and Airbag at a reasonable price for my final interior upgrade.....
RAudi Driver (09-18-2023)
#63
So after several months with the PCCM+ I can give my honest assessment: The sound sucks. The audio quality is terrible and I find myself constantly tweaking the EQ to manage it. The Pioneer system it replaced was light years better but 'haptic only', which disqualified it. Now that I have the buttons back .... that's all I have. Porsche charges well over a thousand dollars for something worth less than a hundred. Very sad and disappointing.
The only good thing to come from this experience has been this thread. It's highlighted an amazing community and some formidable talent in assisting many of us to customise and install this unit.
Thanks All!
Thanks All!
#64
Different experience than yours
I have had it for more than 6 months and my experience is very different from yours.
I have Bose on 997 TT. Sound quality is same as stock pretty good for a 17 year old car. I will say that my 992 GT3 Bose is better despite lack of subwoofer shelf. but again, 997TT is 17 year old audio system.
I wish CarPlay were wireless & it had equilizers. I got $75 wireless CarPlay adapter on Amazon (carlinkit) and it works great. CarPlay works seamlessly. It reboots now & then, but I can live with it.
Do you have Bose?
Do you have Bose?
Thanks All!
Thanks All!
#65
Mine is the non-Bose, though I have a Bose rear deck sub/speaker that I installed. I'm making my comparison to the Pioneer deck that was removed (horrible touch only experience but good sound). Everything else is stock. I'm not looking for SPL competition sound, just something that's EQ balanced and stays fixed within most volume ranges. I actually get static (slight) from the Satellite radio so I no longer listen to that. Seems like the best option is the iphone. Good to know some are having a more positive sonic experience with it!
#66
@bxstrCA I'll echo @sdharmani 's comments, although I've only had mine installed for a couple weeks. I also have Bose, w/o sub AFAIK (I haven't found it yet; think it's typically in the passenger footwell). I'm pretty sound-sensitive and I find the sound quality to be quite good. I'll also echo that the carlinkit Wireless CarPlay adapter works great. I did the mod to my PCCM+ to swap the front "fully-capable" USB port and the rear "limited" USB port, so now I have the fully capable port coming from the back of the headhunt, and I relocated the Carlinkit into the glovebox. Whole thing works and sounds great. My wife who isn't that interested in audio in general even comments on how good it sounds.
The following 3 users liked this post by jalvani:
#67
Hi, new here and fortunate to have purchased a 997 with PCCM plus installed. I beleive it to be in great working order. I have not found any weird sound issues, but I have noticed my lights functioning with some unexpected behavior. I will check a few things that I have learned here in this thread.
admittedly, I found myself a little lost with information overflow so I will ask a question with hope that someone will re-answer or clarify.
I have PCCM Plus plus Rennline magsafe charger. Charger plugged in to the front USB port of the PCCM. is there any way that CarPlay to work thru this connection? or is wireless CarPlay via the Isudar CarPlay board the only way to do this?
if the latter, the Rennline Magsae will remain plugged in to the front and only serve as charging?
Thank you in advance.
Best,
Angelo
Best,
Angelo
#68
#69
Do you have Bose?
Do you have Bose?
Hi @sdharmani and @jalvani , which specific carlinkit wireless carplay adapter did you buy on amazon? Seems there are many, and I'd like to buy the one that worked for you.
Can you please tell me the specific model or maybe a link? I would greatly appreciate it. Thank you!
#70
Only wired CarPlay from factory
@Angelo997C2S - no wireless CarPlay from factory PCCM+ set up. Your options are- 1) cable into iPhone or 2) aftermarket wireless CarPlay adapter. I use CarlinKit.
Best,
Angelo
Best,
Angelo
Donstanley (10-26-2023)
#71
CarlinKit
@othertbone - I would order the latest version they have. When I bought it, it was version 3.0.
CarPlay reboots every now & then. It used to happen with wired connection too - so I am not 100% certain if it is wireless adapter issue. I think it is PCCM+ firmware issue
othertbone (10-26-2023)
#72
Subwoofer
@jalvani - coupe subwoofer is behind the rear seats. If you fold them down, you’ll see it. Convertible is in passenger footwell on left side.
#73
Thank you my friend!
#74
othertbone (10-27-2023)
#75
Sure. I bought the latest: this one. Works great. There are so many flavors though, and each one has a slightly different UI and maybe some additional features (eg. Native Netflix/YT or enabling screen mirroring). This one is pretty barebones but it works reliably. My Mom has the 3.0 version in her Q3 for the past few years and is happy with it.
Aaaah, thank you. I didn't realize location was dependent on cab/coupe.
