All cylinders misfire after driving a few miles
Hi, I have a 2005 997.1 S (3.8).
About 2 months ago, after not driving the car a while (traveling) I started having a problem that goes like this:
Initial diagnosis was old fuel, so I drained it and refueled. No change.
2nd diagnosis was clogged/failing fuel delivery. So, at the advice of a mechanic, I replaced the fuel pump assembly with new OEM.
I drove the car yesterday, and same thing.
Coil packs and plugs have <5k miles on them
Although I'm not getting any specific codes beyond P0300 (or 301-6 for each cylinder)
So, the leading candidates from my searches say
Misfires on both banks; have seen all six cylinders at times.
- Car starts and runs fine.
- After driving ~10 minutes, I feel a shuddering, loss of power and the CEL illuminates.
- If I give the car more gas the CEL flashes yellow and the shuddering intensifies.
- If I key off and restart, the car is fine, but only for a short while.
- When I check the codes, there are misfire faults on all 6 cylinders
- Sometimes when this happened, I swerved the car back and forth to "stir" the tank and the issue would go away for a while.
- It was fine for 10 min (about 5 miles), then the same issue.
- I parked the car and it sat for about 1 hour.
- I restarted it and drove home (about 12-15 min), keeping revs < 2500 and the problem did not recur.
- No CEL, but pending codes, again misfires on both banks
- Crankshaft sensor
- MAF sensor
- Coolant temp sensor
I had a similar issue and it turned out to be a bad evap purge valve (located in the engine bay). My Indy changed it out and the problem went away. I think my issue was that I used too much fuel injector cleaner (multiple times in a row) and it dislodged so much crap that it clogged the evap purge valve.
thrasher (02-13-2023)
Thanks scottrx7tt1, but the chances of both my previous pump and a brand new OE pump having the same issue seem very unlikely.
Carreralicious - I'll look that part up and see if I can test/replace it. My car sits far too much since I wore remotely and also travel for months at a time, so maybe bad fuel/crud (ethanol residue?)
Carreralicious (02-13-2023)
Have you ever cleaned your throttle body? They can get gunked up a bit. I cleaned mine in both the 997.1 and the 997.2. Its easy to take off, get some good TB cleaner and spray it good and wipe off all of the junk. And if it's never been cleaned, you will see a ridge of gunk near the TB plate inside and outside. Then redo the TB calibration adaptation sequence.
Ok, I pulled the MAF and it looks brand new. I cleaned it anyway, but most likely not the culprit. I also looked at the throttle plate and it was silver and shiny on both sides and the entire intake path was spotless.
I could mention that the car had a complete engine rebuild 5,000 miles ago after the IMS grenaded with a previous owner, so it's likely the mechanics replaced the MAF and also tidied everything up. I've had the car since and never had a single issue.
wires are immaculate, but cleaned for good measure (inside and out)
throttle plate also virtually spotless
With misfires on all 6 cylinders, it has to be something common to both banks. How does it drive if you unplug the MAF? That will use middle of the road values for fueling instead of the measured ones. The other thing could be the coolant temp sensor since you say it happens after 10 minutes, which is about how long it takes these cars to warm up.
A bad brake pedal switch will also exhibit this driving behavior, but not usually the CELs. It will just fell like the gas pedal is dead and then a few seconds later come back to life, so that sounds different.
Wouldn't hurt to know camshaft deviation numbers and mean fuel trim values if you have a scan tool that will let you see those live values.
Start with the MAF.
Start with the MAF.
thrasher (02-14-2023)
