PDK advanced advice needed
Hello,
one car reach me not able to crank because somebody tried PDK adaptation by Launch diagnostic which failed and the PDK unit shows "not programmed" failure. So we order new PDK unit and the car started and was able to move but won't shift from 2nd gear. So I run adaptation wia piwis3 clone and it happened the same. Car won't cranc and PDK seems to be again completely erased
I Attached some pictures, any idea?
Sounds like you are trying to do software changes from a non capable source and it's either not completing the task or corrupting it. Can a dealer help?
Owner said dealer tried to fix it too with the same problem and finally they have to put the PDK unit to second car to be able to program it and calibrate it. But I am not able to verify if it's true... Because o found post here where similar problem was solved by dealer
Link to similar topic
Hello, it corrupted by PDK calibration. Two PDK units corrupted by two different diagnostic (launch, piwis3)
I know this won't be any help to you and I'm sorry about that but it may be to others. The PDK is an amazing transmission but it's also temperamental and when something goes wrong it's typically not something you can fix in the garage or most often than not even have fixed at the dealership. I say this after two PDK failures, both of which required full replacements. The dealers are very limited as to what they can do with failed PDK's so in both my failure cases the entire units were shipped to Germany and I got rebuilt units with a 2 year warranty.
Both covered by my Fidelity extended warranty with a $500 deductible. Some are making progress with PDK repairs outside of the dealerships but the biggest hurdle seems to be sourcing parts. Porsche last I heard won't sell internal PDK parts since nobody including Porsche dealerships are supposed to open up the PDK's so therefore they're basically saying....".what do you need parts for. We open up and repair PDK's, not you". Some exceptions to this to which I don't have the details.
The distance sensor was the cause of both my failures and based on other stories here account for most of the failures. I think there was a thread here about distance sensors being produced by someone but I'm not sure about the quality or the functionality of them.
Some years ago I had to have my PDK transmission replaced (long story) and the dealer also insisted on changing the TCS which is the the computer located under the right rear seat.
Prior to the PDK swap I purchased a new TCS from Sunset Porsche hoping to solve the problem as economically as possible. However, I finally had to bite the bullet and get a "new" transmission and and new TCS. I told the dealer that I had a new TCS purchased from a Porsche authorized dealer but they insisted that they would not use it because they would not guarantee the transmission if they also didn't include the new TCS purchased and installed by them.
Hence and for anyone interested, I have two TCS's available for purchase. A new one that was never installed and the original that came with the car which I have no doubt is OK since the problem was with the PDK itself. Please PM me if interested.
I wonder how many of these programming routines have to be authenticated by Porsche AG before they will run. For instance, maybe the calibration routine will erase the TCU in preparation for programming but the auth fails and so it stays erased. That would be an evil way to code the routine, but if you are a dealer it won't happen to you. It would be beneficial if we could get the default programming and at least load that so we could limp to a dealer.
What he said....
What a crap attitude from that dealer. If it's a new part, sold to you from Porsche and there is a problem with it, they should be able to warranty it. Or at least be able to swap it out and ding you for the labor.
Gotta love their our way or the highway attitude.
Hello,
PM if you haven't solve this and need help.
PDK DISPLACEMENT SENSOR
My 2015 911 is in the shop right now with this problem. My mechanic is telling me the same, that PORSCHE does not sell a replacement sensor for this. He thinks we may need to replace the transmission which will cost a fortune. Does anyone have any suggestions on a solve for this? My car only has 55,000 miles, is not a daily driver and is pretty much babied. I am in shock that I'm having to deal with this. Appreciate anyone's input.
i had the dealer reflash the pdk software i n my unit when it was fairly new... it took a bit of preparation with coordination with porsche region head.. i faintly remember that it took a bit of time... like any proprietary software maybe there are codes that need to used to properly do this job.. just thinking out loud
