Grinding and Notchy when Shifting into Second Gear
#46
Congrats on reading my mind on my use of the word "unique" in the above post. Yes, stirring around with the long stick to find a gear, any gear is the unique part of shifting, brought over from the VW box. At least it was not "notchy" or hard to do given the leverage provided by super long stick. Shift throws were a bit longer than today, but still less than 3 feet. This is the box where reverse lived in an apartment all his own. Once you got used to the stirring around in the dark, it was quite satisfying, not fast but a joy to shift. Early 911's (pre 915) also had a non guided bit of stirring around until you learned how to play it. What I do not like is cars that have hard guides to direct your movements via hard gate plates. You know who that is. Too industrial feeling.
Back to my original statement somewhere, Given a trained left foot, right foot, brain, feel, timing and a right hand, shifting Porsche transmissions are a joy.
Riding the clutch with the left foot or keeping you hand on the shift lever or trying to get it to go with brute force just destroys the equipment.
I get you on the gate thing. Now I'm missing another car.
Had a 1979 Ferrari 308 in hard to find Black leather interior I bought down in SF. Gated Transmission takes some of the fun out of it. Like having strict parents.
Had 12K miles and owned by Japanese businessman. Great specimen.
Not a good Seattle car unless you like acid poured on it or door kicked in.
#47
Well said Sandwedge---> I have Function First short shift kit in my car. Also had short shift kit in a few of my past 997's but again whether short shift kit installed or not, tranny always shifted smooth.
FYI as aircooled 911 owners are aware the 915 transmission found in 1974-1983 911's had poor syncros resulting in grinding and almost every tranny needed rebuild. Back then in my 911sc's the cost was about $1500-$2000 for the rebuild.
These days the parts alone cost $2500-$4000 (If you need some gears which many do from the grinding) and labor is another $2500 making the 915 tranny rebuild in the $5-$7000 range.
I miss the old days
I miss the old days
#48
Sounds like you would never own a manual transmission Porsche. The same religion I follow.
I am hearing stories and what little bit I read seems to reflect a very large number of people have lost their minds.
Messing with someone’s car is just plain, well dumb but maybe not too surprising in a place like Seattle.
#49
Landrovers & high end sports cars are targets.
My wife's Mercedes sedan gets it's front license plate twisted/deformed every so often.
#50
I thought the cutoff and introduction of the better G50 Transmission was 1984 but forgot it started in 1987 and why the 87/88/89 911 Carrera was a great example to own.
#51
Small correction to the reply above. It should read "sounds like you would ONLY own a manual transmission Porsche." Yes that is true. In fact I have only owned one auto transmission car which was a '57 Ford convertible that I converted over to a stick when I was 17. We are a dedicated 3 pedal family..
Also great looking '53 pre A.
To clarify the clarifications; My findings and opinions are that all Porsches are easy to shift and given that they are rear engine rear drive, it is a miracle of engineering. (Unless there is actually something wrong with the car.) The Porsche patent balk ring synchro was used from its inception in 1948 up until 1987 when they finally caved to using the Borg Warner cone brake style that dates back to the thirties. My '32 and '40 Fords have Borg Warner brass cone style synchros. Why the change at Porsche away from their own patent style snychro? The balk ring was smoother than the B W style, but more delicate. As power goes up being delicate and robust becomes a challenge. Thus the change in 1987 and for the modern world the same deal as seen in the 997's and the Asian gearbox. The synchro is a friction brake and more power requires bigger brakes.
In all my Porsche years I have never heard a discussion or complaint about Porsche shifting until the 997 era and it is always from new to them owners. In all or most cases this goes away with time-practice. The new series of transmissions are certainly rugged in order to carry the power (torque load) which is 5 to almost 10 times what we started with and to make it worse the world wants short shift throws which reduces the leverage Given all that, the 997's shift great and I have no complaints.
To star a t potentially new controversial discussion, I wonder how many of the newer Porsche car owners started their driving careers on stick shift cars and have only driven stick cars? If you started out on stick cars you have learned over the years that they all have differences but you learned to operate them effectively. Like playing guitar, it takes a lot longer than you realize.
A couple of fun pics to get back on topic (sorta)
Here is the simple 519 gearbox used in the pre-A. Simple with Porsche synchros. VW with reverse outside in the nosecone. Like always, parts were had to find. You had to know Chuck Stoddard.
Both of these cars shifted great even though one was a jalopy at the time I took this picture.
#52
^^When I bought my 1953 Pre-A it came with a spare 519 Transmission on a crate.
Miss the 356 days! My 1959 Super Sunroof was a great find. I restored it in Ukiah California - Only needed paint and I flew down to put it back together.
Some photos after paint and then next trip down to get it ready for drive home.
#53
Looks great! The A was the last of the good looking 356 series in my opinion. Porsche was having to deal even then with modernizing their cars and still keep with an iconic image. Fortunately they had enough money and threw in the towel and voila the 901! The 997 is kinda the 356A of the modern series.
Great coupe and modern convivences like windows and they even roll up.
groovzilla (05-07-2023)
#54
groovzilla (05-08-2023)
#55
Mobilube PTX
Hello all. My second gear is still driving me crazy when gear oil is cold. Once warmed up all ok. Has the Mobilube PTX really helped? I’m bringing my car back to the shop. Thanks in advance for your replies.
Rob
Rob
#56
Grind Into Second Gear
Just when I thought I got it down. My 2010 Carrera S sat for a while and it’s been in the 30’s. As soon as I tried to shift to second it grinded. Again if I pause no problems. Once the car’s temperature is up then all is smooth. Frustrating
#58
PTX
Yes, I did change to mobilube PTX. Still have to pause for a sec before going into second gear when the car is cold only. I have been told by 3 mechanics that my car is normal. IDoNo. Lol
#59
I think you can chalk a lot of your issues up to your driving environment. Most, if not all, of the people saying they have never experienced an issue
selecting second gear when both the weather and vehicle are cold, live in warmer climes. If you're out and it's in the 30's I think you just have
to be ready to really take your time selecting 2nd gear or reverse for the first few miles of operation.
I've owned and driven manual transmission cars for my entire life and have owned my current 997 for over eleven years. I have experienced the second gear crunch if I'm not super
patient on a chilly morning (sub 50's). I've double clutched and also selected another gear before selecting reverse. All these operations will help, but I think the common denominator is taking a
few beats before you select second or reverse. And by a few beats, I mean like a Two Mississippi count .
I look at it as an inherent trait of the car.
On the bright side, you're out enjoying your car in weather that many owners won't brave, so hold your head high
Hope this helps,
Bill
Hope this helps,
Bill
#60
im in the same boat. I feel like if you pump the clutch a few times it actually helps?
