Repair 997.2 LED Tail Light Assemblies?
Anyone familiar or aware of a shop that will repair 997.2 LED taillight assemblies? I just drove my wife's new (to her) 997.2 S Cab home to Fort Worth from Mesa, AZ and realized during the nighttime portion of the drive that the right rear taillight is not working properly. Backup light, stop light and blinker all work just fine. It is simply the taillight that does not work. Checked fuses just in case and all good on that end. There's no reason for there to be a wire short, so I'm wondering if the taillight portion of the assembly has had an unusual failure. With new parts running upwards of $2,500+, I would really rather NOT spend that kind of money. I may be forced to buy a Uro replacement to get the car inspected and licensed for Texas, but I would like to be able to repair the taillight if possible.
Any suggestions? Thanks in advance.
Toby
Toby
2009 C2S 192K miles
I had a partial tail light failure.... I just unplugged the cable and shot some contact cleaner in there... and pressed the plug on real tight. For some reason, something was out of spec in the plug and I had to press it together with force.
Peace
Bruce in Philly (now Atlanta)
Peace
2009 C2S 192K miles
Peace
Peace
Toby
Peace
Toby Pennycuff (10-02-2023)
I ordered a driver’s rear ULO taillight but found a set locally so I have sell ll this one $475 shipped cost me $545
The clear lens separates from the red lens. Water gets in. Porsche designed the vent hole to be at the top of the assembly. So the entire taillight gets flooded before any water escapes. I drained over a quart of water out of mine. Then I cleaned the contacts before reseating the plugs (there's no such thing as a good connection ... unplug and plug in many many times).
I also drilled weep holes in the bottom of the cover piece.
My result? It worked for a couple months before I had to attack the connector again. It worked a while longer and then fully failed.
Nite ... Same failure as yours ... parking light wouldn't light.
I hit up Ebay and bought a new assembly from Latvia.
Lesson ... Proactively drill weep holes at the assembly bottom and add clear PPF to keep water out even after the lenses separate.
EVOMMM (10-02-2023)
@Wayne Smith That's a good idea. I'll look into that once I get the car back. I'm hoping (for now anyways) that a simple unplug/connector fluid spray/re-plug will get it going so I can get a valid state inspection. Then I can deal with it in a more leisurely fashion!
Toby
