View Poll Results: OEM or aftermarket shifter?
OEM
22
56.41%
Aftermarket
17
43.59%
Voters: 39. You may not vote on this poll
OEM vs Aftermarket shift knob
OEM vs Aftermarket shift ****
I’m due for a new shift **** and am torn between the OEM options and the aftermarket ones. Curious to see what RL thinks…
I have a factory short shift kit and am not going to swap out the whole shifter. I’ve toyed around with the idea of changing the cables, but for now what I really need is a new ****. My leather is worn and the silver cap is starting to chip too.
I’m leaning towards either OEM stock shifter or a FF delrin shifter in silver. I don’t have any carbon trim in the car so I’d get a regular leather OEM replacement.
2009 C2S 193K miles
Post what you are looking for. I have the Numeric as it gives you height options... I opted for stock position... and provides metal-to-metal parts with ball bearings resulting is a good feel. Stock is all plastic. I am happy with the Numeric albeit an expensive unit. Its about feel.
Peace
Bruce in Philly (now Atlanta)
Peace
Go aftermarket. Have some fun.
The following 5 users liked this post by nwGTS:
aasilvia (11-03-2023),
ATX_Native (11-03-2023),
Elliotw44 (11-03-2023),
preelude (11-07-2023),
Spastblast (01-16-2024)
Nate! It's a bit ironic (?) installing a lightweight stratified birch/ash wood **** (created to honor the 917 balsa wood ****- which was created solely to save weight) and then adding internal weights for a better shift feel.
Maybe not ironic...but certainly counterintuitive.
https://brakebanzeen.wordpress.com/2...s-wooden-****/
I have a factory short shifter and added Function First cable ends and their Shift-Right Solution, results were much nicer in terms of feel and gear engagement. I had a Raceseng Circuit Sphere in a previous car and put one in the Carrera. It weighs just over a half pound and seems to provide another bit of direct engagement. It's fractionally taller than the stock shift **** and falls nicely to hand, also doesn't get hot in the sun.
Rig.Stunts (11-03-2023)
Everytime you drive your car you touch the steering wheel and shift ****, might as well touch something nice.
This thread has all the info you'll ever need regarding shift ***** https://rennlist.com/forums/997-foru...-****-sfw.html
If I had bought it to save weight and then added weight to it, that would indeed be ironic.
Liste-Renn (11-04-2023)
2 x Raceseng Circuit Sphere!
Replaced the scarred and sloppy plastic OE ****
Delrin over metal please
The following 4 users liked this post by Carreralicious:
OEM XFN ****. Heaviest OEM **** available.
buddalun (11-15-2023)
Recovered in Alcantara with a GT3 short shift kit
Liste-Renn (01-12-2024)
