20" RS Spyder Wheels on a 997
Anyone running the 20" version of the RS Spyder Wheels on a 997, thoughts? I am considering this, but curious if anyone else has tried the fitment. I have always liked the way these wheels looked, and I see used sets come up here and there as 991 owners swap them out.
Not trying to debate 19 vs 20 wheels and the increased chance of bending a wheel due to pot holes.
EVOMMM (03-08-2024)
I have a version of these wheels (as 21's) on my Cayenne.
May not be an issue for you, but I can tell you firsthand that they are a pain to clean and keep clean.
Where each of those spokes intersects with the rim - specifically the inside corners - collect brake dust, dirt, and assorted grunge.
If you are thorough with regular cleaning (and if you have the wheels ceramic coated) then, not as big of a problem.
I agree - good looking wheels, but...
Skube (03-08-2024)
What are the widths and offsets of the wheels you're considering and what year and model is your car.
Oh, and 20s are too big
vg247 (03-13-2024)
Yes they will fit.
OEM Specs for those wheels (double check this):
8.5Jx20 ET49 (No spacers needed)
11.5Jx20 ET76 (15mm Spacer Needed)
(You will need 245/30/20 Tires (Front) and 305/25/20 Tires (REAR) )
Those were my favorite wheels on my 991.2.
EVOMMM (03-08-2024)
I also like them, I went with the HR 20" which I thought would be horrible, due to the streets and roads in NJ, but fast forward a decade and It is fine, My 997 is my DD - I thought my older C4S (996) drove harder with 19" turbo wheels -
20" HR wheels and HR Sport Springs, Lowered
Graufuchs (03-13-2024)
I have a 2009 C2,
This is the math I come up with, I found a set with tires installed, and I dont think they will work, would need to replace the tires with 245/30 R20 Front & 305/25 R20 Rear
Can run the fronts without a spacer.
Would need to keep the current spacer with the RS Spyders
I have a 2009 C2,
Ok so you have the exact offsets, perfect, I am running the same sizes with those tires I suggested. 12/15mm spacers will work in rear. I have a rear offset with the BBS wheels of 65mm with a 12mm Spacer.
Effectively Front 49mm and Rear 53mm. Wheels are flush to fenders. The ride is surprisingly pretty good.
Skube (03-15-2024)
As others have said, you can't run 245/35/20. They will hit the strut spring perch. If you want to stick to 35 sidewalls you'll need 235/35/20.
Personally, don't like the look of 30F/25R sidewalls..
I've run 20s on 2 997s so far. Both with 235/35/20 and 305/30/20
20x8.5/11
20x9/11.5
20x8.5/11
20x9/11.5
The following 2 users liked this post by arscottp:
Skube (03-15-2024),
tegraphile (03-16-2024)
Graufuchs (03-15-2024)
@Graufuchs I believe I have the same wheels and need new tires. Currently running 235/30-20 in the front. Is your car lowered and do you have any issues with rubbing with the 245/30-20 in the front?
[/QUOTE]
[/QUOTE]
