Announcing the Sport-Chrono replacement gauge
Basic Site Sponsor
Basic Site Sponsor
This is @Hatzenbach posting from my Rennlist vendor account to stay in compliance with the Rennlist rules.Yes, the device that many have been waiting for is finally available and ready to ship!
What is it and why do I want one?
Anyone who has the SportChrono option in their 997.2 is probably wondering what to do with it. I found it 100% useless. So, I decided to make it useful.
It is an instrument that replaces the SC clock. Because the analog instruments for oil temp and water temp in the dashboard are less than accurate - and sometimes hard to see (oil pressure), its main purpose is to give you accurate readings on coolant temp, oil temp and oil pressure.
How does it work?
I am taking all readings directly from the ECU via the CAN bus.
The device has 5 modes:
You can switch the temperature display between Celsius or Fahrenheit.
I like to keep things simple and decided against additional buttons to control the device. The different modes are either auto-selected (for example when you select "Sport mode") and can also be switched by "double clicking" the PASM button. In case your car doesn’t have PASM, you can control it via an external push button.
How difficult is it to install?
The difficulty in installing this is 3.5/10, please read the installation / user manual, to understand what needs to be done and then decide if you feel that you can do that.
Sounds great, how do I get one?
Go to my online shop: www.997research.com click on “Shop” and order one.
Any caveats or gotchas?
How does it work?
- Mode 1: analog clock
- Mode 2: analog clock but with two additional dots at the top and bottom, that indicate the oil temperature (top) and coolant temperature (bottom)
- Mode 3: temperature display (simple)
- Mode 4: temperature display with bars, which change color based on actual temperature.
- Mode 5: oil temperature on top and oil pressure on the bottom (you can finally observe your car’s oil pressure without having your view blocked by the rim of the steering wheel!)
- Your car needs to have the SportChrono option (duh)
- Currently only the following models are supported (I am working on supporting more models):
- 997.2 Base
- 997.2 S / 4S
- 997.2 GTS
- You need to physically tap into the CAN bus (please refer to the manual for details)
- I have created a limited stock of these devices. When the first batch is sold, I will create new devices “on demand”, which means there will be a couple days delay between ordering and shipment.
- Currently I am only shipping within the United States. I will make it available for international shipping later.
want automatic headlights in your 997/987?
Go to www.997research.com
The following 12 users liked this post by 997research:
997.2GTS (03-31-2024),
cvalue13 (03-31-2024),
emjohn43 (04-05-2024),
Graufuchs (03-31-2024),
gutenfreibier (03-31-2024),
and 7 others liked this post.
Hatzenbach (03-31-2024)
The following 9 users liked this post by Hatzenbach:
99Seven (03-31-2024),
bhag meister (04-03-2024),
downtroddengoat (03-31-2024),
and 4 others liked this post.
Ordered about an hour ago, and I haven’t even owned a 997 yet (transport is close though!).
Before ordering, I read the install/operation manual through. It is clearly organized, detailed, and with perfectly helpful step-by-step photographs. Gave me comfort I could do this 3.5/10 install (my upper limit being 3.6).
This will be my first (and rare) mod, just as soon as both the gauge and the car itself are both received.
only regretting I didn’t go ahead and snag that auto-headlight mod while I was at it.
thanks, cb in ATX
thanks, cb in ATX
thanks, cb in ATX
thanks, cb in ATX
Congrats on your new car. Pics or it never happened!!!!
cvalue13 (04-04-2024)
thanks, cb in ATX
thanks, cb in ATX
well, since you're the FIRST person who ordered the SC gauge AND in appreciation of your nice comments, I just threw one of the headlight modules into your package as a token of my appreciation.
Enjoy!
Cheers
Chris
Hatzenbach (04-01-2024)
got delivered back to HTX (long story) this morning (it hath risen!), and if things go as planned I’ll fly down to grab it on Wednesday, drive it back to ATX
but here’s a pic (from my buddy giving it to me), in his garage a few months back, then one of the OD from when the transport scooped it up
myw (04-04-2024)
The following 2 users liked this post by Wayne Smith:
Hatzenbach (04-01-2024),
Uwon (04-01-2024)
Super cool mod.
Would be very interested in one for my 997.1.
Cheers,
Johan
Cheers,
Johan
Hi @cvalue13 ,
Enjoy!
Cheers
Chris
Enjoy!
Cheers
Chris
cvalue13 (04-01-2024)
How does it work?
How does it work?
- 997.2 Base
- 997.2 S / 4S
- 997.2 GTS
Count me in if you make a 997.1 version!
