Mobil 1 0W-40 Fans - 997.2 Owners Take Note
Umm... compression ratios.... isn't the compression ratio for a .2, 2010 911 Turbo 8.5:1 ? That is not high. For a 2010 Carrera S, it is much higher at 12.5:1 ... and LSPI occurs at low RPM under high-torque conditions typically between 1200 to 2700 rpm... below use of turbocharrges... no?
Peace
Bruce in Philly (now Atlanta)
Peace
All the technical references I'm finding suggest LSPI is primarily an issue with turbocharged DFI engines. Not specifically the 911 Turbo: like, nobody's saying "all turbocharged DFI engines are at risk of this", primarily it's high compression, low-displacement turbo DFI engines when you operate them at low RPM and high load.
I've never heard of LSPI being a concern on the 9A1 engine, nor have I seen any super knock codes on my particular engine despite using Mobil 1, and the video is wrong (or, at least, out of date) on the Mobil 1 0W-40 API SP rating. This is a nothingburger.
Lot of you guys with the oil additives and specialty motor oil are just buying into marketing. Liqi Moly is a favorite: "We make the best motor oils in the world, except they also kind of suck so we'll also sell you this extra additive to make them better". Gimme a break. Buy an A40 oil and change it regularly and you'll be fine.
maschinetheist (04-16-2024)
No, I'm not watching a 15 minute advertisement for Driven oil. What was I just saying about marketing?
Seriously, show me any evidence of LSPI being an issue in the 987.2 or 997.2 engines. Anyone seeing a lot of broken rings or holed pistons? Bunch of knock events stored in the ECU?
Maybe Porsche knows what they're doing when they spec an oil?
ADias (04-14-2024)
Slightly off topic, I do like Mobil 1 Racing 0W50 and that's what I use for my .1. It got strongest additive pack I can find and enough detergents for street driving as well. And it is cheaper than the Driven oil....
https://www.speediagnostix.com/new-o...chaeffer-gdbte
Robocop305 (04-28-2024)
RedBoxCarr (04-17-2024)
Any advice then for a better oil than the Porsche recommended Mobil 1 for the 997.2 I see LiquiMoly, Motul and other talked about but if you were to choose the best for 12m and 4k miles of 50% standard use and 50% spirited driving what are the recommendations for a 42k miles 3.6 ?
It's mostly internet scaremongering. Mobil1 0W-40 is SN+ & SP rated, that means it's passed the latest LSPI testing. Porsche also used (uses?) it as factory fill and it's one of their A40 listed oils. The cognitive dissonance between "Porsche has amazing engineering and makes the best cars" and "these cars will explode if you even wave the wrong bottle of oil near them and also Porsche uses and recommends crappy oil" on this forum is mind-boggling sometimes.
And yet there's no evidence that that makes any significant difference in wear. It's a great example of people playing in the nose of the data: the wear numbers or some other value fluctuates a bit and people convince themselves it's significant. Why is being slightly low on the arbitrary line between 40wt and 30wt an issue? Why 40wt particularly then? If more viscosity is better, shouldn't you be running 50wt?
I mean, you've literally got Blackstone telling people that they've never seen any significant difference between brands, and yet people insist on using their UOA numbers to try to convince themselves they need some magic motor oil which is almost certainly made by one of the major companies anyway. But, hey, what does Blackstone know? They've only got thousands and thousands of data points, right?
https://www.blackstone-labs.com/which-oil-to-use/
"The only difference between these products and the major company brands is the name on the container and the price. Don’t believe us? Try running your own experiment: do a sample on Oil A after a known number of miles, then do a sample on Oil B and compare the wear levels. You may see a little fluctuation, but it’s very rare for one oil to make a significant difference in an engine’s wear patterns. "
If the object of an oil is to reduce metal wear then the oils that show the lowest metal ppm are the best oils. If you don't care about your engine wearing out internally or don tkeep your cars for a long time, then you're right, they're all "good enough".
The following 4 users liked this post by Petza914:
I am thinking of 10W50 Millers CFS NT+, Hartech use this and looking at the reviews seems it offers good protection and I do find the mechanical noise can be higher than I might like when the engine is hot (tickover) and moving to improved viscosity at 100 deg C, might help ?
For those with m2s, the Driven DI40 is actually a 5w40 and being rebranded as such. It was always borderline between a 0 and 5 when cold and the original bottles and press releases called it a 5w40, then it was relabelled as a 0w40, but is now being relabeled again as 5w40 so don't worry about that being too thin when cold as it's fine and what I run in my DFI Cayenne Turbo S and my DFI Audi Q5.
Personally, I like a 5 cold viscosity rating for these engines. Flows well when cold and provides a bit more film strength protection on initial startup. 10 is getting a little thick for the tight tolerances in these on cold start in cold conditions. The 50 when hot is good though and why I run the Driven FR50 5w50 in mine.
Looks like Driven DI is not available across the pond, this might be a contender ? https://pim.liqui-moly.de/pdf/en_GB/liqui/21/P000348
Carrera2RS (04-15-2024)
In was thinking, perhaps I could add the MoS2 to Mobil 1 for a few miles ? My oil was changed only 700 miles ago with the usual Mobil 1 0W40, so perhaps rather than changing straight away try the MoS2 to see if it reduces the increase in noise when hot ?
BillB128 (04-15-2024)
It's not actually. I can look at a UOA report after 3-5k miles of use and tell you which of 4 or 5 used in the 997s it is based on metal wear, zinc and Phosphorous levels, and viscosity. M1 and LM (other than Molygen) show higher bearing wear numbers than Driven or Motul. M1 shows low viscosity and higher aluminum wear than the others.
It's your money, and if you feel better buying expensive motor oil go for it. But I see no end of people on the internet who couldn't engineer their way out of a paper bag trying to convince other people "you use Mobil 1 0W-40 and yOuR pOrSchE wiLl AspLodE!" and its like...based on what? A poorly researched YouTube video about LSPI? A 15 minute infomercial by the guys trying to sell you the expensive motor oil? Cherry-picking data and convincing yourself that 7ppm vs 5ppm Al in an uncontrolled test makes any actual difference? Nah.
