classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
Thread Tools | Search this Thread |
#61 | |
Rennlist Member Join Date: Oct 2005
Quote:
I don’t know why I wouldn’t want to mention my method to a Porsche mechanic; it will certainly cause no problems if you’re not a klutz. ![]() I realize that pre-filling the canister is not necessary but it can easily be done. Maybe you don’t possess the necessary skills to do it without making a mess (I didn’t spill a drop) but that is no reason to be such a condescending know-it-all. I did in fact change my own oil on my 997S and as far as your second statement I think you are the one that is confused. The oil filter element does get seated inside the canister. If you look inside the canister you will see a round metal sleeve on the bottom of the canister, the oil filter element seats into that sleeve. You can either seat the oil filter element by physically pushing the oil filter element down into the canister before re-installing the canister to the engine or it will seat itself when you screw the canister back into the engine but the oil filter element does get seated into the canister. Are YOU sure YOU changed oil yourself on your Porsche?
2007 Slate grey/black Carrera S with X51, PCCB and some extra paint, leather and carbon fiber. |
#62 | |
Quote:
If you want to document your own procedure with your own recommendations I suggest you do so. But for now, I'll go ahead and close it up since the instructions here are pretty complete as it is. |
#63 |
Just wanted to summarize the torque values given by the Shop Manual in one post for reference purposes:
Oil Drain Plug: 8mm hex: ... 37 ft-lbs Oil Filter Hsg Spanner Tool: 27mm socket: ... 19 ft-lbs Last edited by OCBen; 11-13-2006 at 10:55 PM. Reason: typo |
#64 |
Rennlist Member Join Date: Nov 2006
Performance Products makes such a drain plug. It drains out with out taking the bolt loose.
![]() ![]() -2002 996 C2, Black/Gray, Bi Xenon Litronic, Heated seats, Smoked Lenses all around. Fabspeed muffler bypass. -1998 Boxster Black/Black, SOLD |
#65 |
User
great write-up! will be using this as a reference soon. Car is at 6500 on the oil, and a change is due.
#66 |
Rennlist Member Join Date: Jan 2004
Thanks Ben for the write up!
John "JFScheck" Scheck '11 Audi TTS 2.0T 265hp 258lb-ft S-Line Quattro - Volcano Red Metallic '11 F-350 King Ranch 6.7L 4x4 SB SRW - Forrest Green & Chaparral Leather '11 Lincoln MKZ Hybrid Boreadux Red & Cashmere Leather '06 911 S Club Coupe with "381+ horsies" - Azurro California '11 30 Airstream Classic Limited - Praline Leather & Hickory Wood "Enjoy life. There's plenty of time to be dead." **I Love U.S.A.** |
#67 |
Not an Addict?
Rennlist Member Join Date: Apr 2006
Ben:
I'm going to be changing the oil soon. Can you please come over (to the Henderson House) and help? Then we can go and play. Lots to do out here. We can go flying, or to The Strip, shooting up in the local hills with some of my buddies, or to the gun show coming up. Of course, that is after a stop at Whole Foods or one of the numerous restaurants in the nearby District for some din-din. Okay...you can bring the wifey too. We just won't go to Cheeta's then. I've printed up your oil change instructions (in case you forget how in all the excitement), and have the Porter Cable ready for all those darn swirls I tried so hard not to get. Oh yes, I also have some of your favorite indulgence.See ya soon.
Best Regards, DarioF. ![]() My Rides: 1951 Spaceship (In My Avatar) 2006 Carrera S CAB 2008 Mercedes GL 320 CDI (Diesel) 2011 VW Jetta Sportswagon TDI (Diesel) Last edited by Dariof; 03-15-2007 at 11:04 AM. |
#68 |
Poseur
Rennlist Member Join Date: Nov 2005
I think I'm going to epoxy in a small magnet onto an extra aluminum oil plug and put it in during my next oil change. It will be interesting to see if anything shows up on it. I miss that from the older 911s//930s.
Dan 06 997S PCCB Hard-Top Cabrio Turq. Blue, Nat. Brn Leather http://www.rennteam.com/photopost/sh...00&ppuser=8756 |
#69 | |
Quote:
#70 | |
Quote:
#71 |
User
![]() ![]() ![]() Wanted to thank OCBen for getting back to me so quickly. My 997S was way overdue for an oil XCH so being a first for me I had a few critical questions that he answered that were already evident in his posts (I am slow to understand things!!!). One thing I felt worthy of mention is that the FLOTOOL oil filter wrench size #7 definitely lacks in fitment. I plan on returning mine for the metal one or for a different brand that fits better. In order to complete the task I had to cut two strips of paper and use them as a spacer/shim between the oil filter housing and the wrench itself. This does work. But why bother if I can get the right fitting wrench for the next change. In addition, I put together pieces of 2X6's (dual layer to build up 4inches of elevation) that I happen to have until I had four sections each of them 4 inches thick. I then used a jack to lift each corner of the corner placing the dual layer of 2X6 under each tire. This worked for me since I already had the material. I plan on mitering the 2x6's so I can drive the car onto the 2x6s next time!! |
#72 |
Rennlist Member Join Date: Jun 2004
Did it last weekend and worked like a charm. Thank OCBen. Had a little difficulty with the air filter change but got it okay. Thanks again.
===================== '09 997 Carrera 4S - Meteor Gray/Black (mine) '12 Audi A7 - Gray/Black (mine - daily driver) '11 Panamera V6 - Carbon Grey Metallic/Black (herz) '10 BMW X6 35i - Space Gray/Black (all hauler) Kids..matched set - OURZ ![]() |
#73 |
Rennlist Member Join Date: Feb 2005
I also done the oil change myself today thanks to this thread. The strange thing is the computer didn't show any warning about the oil is low. Everything went smooth. This is the first time I changed oil on a car. The only thing I am not sure is where to install the "o" ring.
I just put it around the oil filter in the canister. Can anyone please advise if thats correct? If not I can still go fix that. Thanks.
#74 |
User
Out of curiosity, where do you guys buy your filters? I asked the dealer how much they charge, for a laugh, and obviously I am not paying $47 for an oil filter!
#75 | |
Impeccable record
Quote:
http://e-partssales.com/Merchant2/me..._Code=997maint
Coochas aka Dave -'09 997 TT RS Orange|-'99 Spec Boxster 3.4 Black|-'12 Spec Racer Atom Black/RS Orange (being built!) -'11 BRE Aerovault|'10 Ram 2500 Diesel|'10 Mini S Conv|-Cayenne TitS Purrrr Red -Porsche e-Brochures -NCR/NER PCA DE Instructor |
| Tags |
| 2700, 997, 997s, cars, change, correct, drain, drove, miles, oil, overfill, plug, porsche, procedure, ramps, torque, wheel |
