DIY Oil Change in the 997
Old 10-12-2007, 07:08 PM
  #76
Crazy Canuck
Crazy Canuck's Avatar
Originally Posted by OCBen
I'm sure you also invited him over for one of your famous pig roasts on the river bank, right Chris?
He's the friend who does it with me.
Old 10-12-2007, 07:13 PM
  #77
Crazy Canuck
My independent uses Bosch oil filters.
Old 10-12-2007, 07:35 PM
  #78
bird man
8th Gear
bird man's Avatar
I paid $22.99 for mine from kragen's. They get it from the warehouse and I then pick it up the next day. The box it comes in is a FRAM CH8278 but its a MANN FILTER. Carlsen Porshe charges $25.00 for their filters.
Old 10-12-2007, 07:39 PM
  #79
bird man
8th Gear
bird man's Avatar
Originally Posted by Rivan
I also done the oil change myself today thanks to this thread. The strange thing is the computer didn't show any warning about the oil is low. Everything went smooth. This is the first time I changed oil on a car. The only thing I am not sure is where to install the "o" ring. I just put it around the oil filter in the canister. Can anyone please advise if thats correct? If not I can still go fix that. Thanks.
rubber black o- ring replaces the original that is on the oil filter screw on cap
Old 10-12-2007, 10:56 PM
  #80
Rivan
Rivan's Avatar
Thanks!
Old 10-28-2007, 07:10 PM
  #81
Dariof
Not an Addict?
Dariof's Avatar
Having driven my P-Car for approx. 8,000 miles in 16 months, I felt it was time for an oil change.
My friend (Slant911) came over to help, since this would be the 1st time I have changed the oil myself. (The dealer did it at 2,000 miles). Also, my friend has changed the oil on his Turbo several times, so I knew this wouldn't be too difficult.
Armed with Ben's detailed instructions, which were pre-read and understood prior to my friend's arrival, we started the daunting task.
I drove the car just outside the garage, and placed the rear wheels at the point where my driveway starts to slope downwards. (Sorry, no pics yet).
This gave us plenty of room to crawl underneath the level car and get to the oil filter and drain plug.
The rest was a snap by following Ben's instructions to the letter.
Thank you, Ben. This was about the easiest oil change I have ever done.
Old 10-29-2007, 04:55 PM
  #82
NVRANUF
NVRANUF's Avatar
what's the actual size of the oil filter housing tool we require?
Old 10-29-2007, 09:46 PM
  #83
bird man
8th Gear
bird man's Avatar
I myself am not sure, I just know the FLOTOOL #7 will sort of work in loosening and tightening if you space it with slips of paper like I showed in my posting.
The FLOTOOL #7 is not a tool to keep!!!
Old 10-30-2007, 03:10 PM
  #84
NVRANUF
NVRANUF's Avatar
Any issues in doing the oil change with the engine cold?? Other than a prolonged drainage period....
I prefer to not add any further header "brandings" to my arms for this year....
Old 10-30-2007, 03:50 PM
  #85
gota911
Newbies Hospitality Director
gota911's Avatar
It is a 74mm, 14 flute oil wrench
Old 02-23-2009, 03:37 PM
  #86
Sadiq
Sadiq's Avatar
bump thanks
Old 02-23-2009, 08:23 PM
  #87
FlyingLow
FlyingLow's Avatar
Ben, can you teach me how to change the oil in my turbo? Hope you're doing well. I've been in Switzerland but I'm back now!
Old 02-23-2009, 08:53 PM
  #88
gray911
gray911's Avatar
Is it the same process for a 2009 carrera?
Old 02-24-2009, 01:12 AM
  #89
OCBen
OCBen's Avatar
Hey Steve-o! Sure buddy, anytime. I'll supervise while you do the work.
Oh, and make sure pizza and beer mysteriously appear somehow!
The process is the same for all Porsches without a dipstick: drain, replace filter cartridge, and add at least as much oil as you drained, and then add a quarter of a quart at a time until your electronic oil gauge indicates a full condition, although it's perfectly okay to leave it one segment shy of full, which is what I would do if that's what I read. It's better to be slightly less than maximum than more than maximum. And with our electronic dip****s it's better to be safe than sorry - i.e. somewhere between minimum and maximum than exceeding maximum.
Old 02-24-2009, 06:28 PM
  #90
Minok
Minok's Avatar
Default 2009 997.2 3.6L engine
The canister for the oil filter is easily accessed from the top now:
Quick Reply: DIY Oil Change in the 997
