2006 Cayman/C2S mp3 capability?
I have both a 2006 Cayman S with the CDR-24 radio plus the disc changer and a 2006 C2S with nav and changer. Both are supposed to play mp3 cds. I cannot get either to do so. I am trying to play them in the single dash slot. I have burned them on different cds. I have burned them on a pc and a Mac using different programs. I have read many posts saying that both radios should be able to play mp3s. Is there some light that can be shed on this by anyone ?
The nav unit is the newer style with the SOS button.
The CDR-24 is not MP3 compatible. The only way you can play MP3's is with the PCM and that actually only applies if the software revision is beyond 2.1.
You can tell the software on the PCM by pressing MAIN & TRIP together which should show the info at the top of the screen.
Regards
Popolou
Regards
Popolou
I was in for an oil change recently and the mechanic indicated that Porsche should be releasing soon an adaptop to allow the PCM to connect to an ipod. Can't wait to see if it works ok.
