C2S vs. C4S
At a glance, the wider rear is fairly obvious. The inch or so wider doesn't sound like much, but it is. Also, a C4 has a smaller front boot. If none of those work for you, check out the rear tires. The C4 comes with 295 series tires, the C2 with 265 series.
1 Post
If we don't mind to crawl down with a flash light, we could check if there is the shaft runninhg from the rear to the front driving the front wheels on the C4(S).
With best regards,
With best regards,
Poseur
Actually, you would be wasting your time. The bottom of the cars are so well sealed yo would not see a thing. The best clue is the little "4" glued on the back panel... ;-)
I've seen more than a couple of '05 C4S' that only had the Carrera S insignia and I don't think that they had been changed. Also, I was told the C4S rocker panels are not completely painted (black strip on the bottom portion).
How did you determine that the car with the Carerra S insignia was in fact a C4S - I thought that was your original question - how to tell them apart.
Now we're getting somewhere, so there weren't any '05 997 C4's.
The C4's that I claimed to have seen were listed by dealers (typos, I guess).
