Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 Forum
Old 07-27-2009, 05:37 PM   #46
Minok
User
Minok's Avatar
Brake fluid change every 2 years is typical across all makes as the fluid will absorb any moisture it can see from the air, etc. If you end up with moisture in the brake system it starts to impact the way the hydraulics work, and the moisture can affect the steel bits of the braking system in the calipers over the very long term (like if you only change the fluid every 5-10 years). Still flush, refill, bleed.. its the same process on a 911 as on a Honda..
Coolant? I thought the cars came with 'lifetime' coolant?
Minok is offline   Reply With Quote
Old 07-27-2009, 06:39 PM   #47
997, esq
User
997, esq's Avatar
Quote:
It does depend a bit on where you live. Moist areas, such as your Pacific NW, probably require more frequent changes than Tuscon, Palm Springs, LA, etc.
FWIW, I got the fluid changed at an Indy for $90 at 2.5 yrs, 20K miles. It's an easy job to DIY, if you like doing that sort of thing. $300 is a flat out waste of money. I guess Porsche dealers figure that people with money often don't know what is involved in these things and that they will pay basically anything.
997, esq is offline   Reply With Quote
Old 07-27-2009, 06:48 PM   #48
OldGuy
OldGuy's Avatar
A brake fulid change with the Power Bleeder ($70+ATF blue $16) is easy and you and your kid
can do it in an hour. Oil change is easy to do (on a GT3 with a dry sump) and parts + oil is $90.
The air filter on a GT3 took 5 minutes all parts available from Pelicanparts.com
I havent checked the air and oil filters on this new one.
OG
997 09 C2S PDK
Carrera White
Rennlist member# 030815-4002
Official NRA Liason to Sierra Club HWFMR
paulgt3@gmail.com
2008 BMW 335i (wifey's)
2006 BMW X5 4.8iS
04 GT3 RSR Le Mans entrant
Gone 97 993 TT midnite blue/cashmere(missed)
04 RED 996 GT3
2007 GT sliver GT3
2009 AMG C63
OldGuy is offline   Reply With Quote
Old 07-27-2009, 08:03 PM   #49
MLindgren
MLindgren's Avatar
WTF are they doing to clean the fuel injectors beyond dumping some crap in the gas tank.
Can somebody shed some light on this.
I need to and see what is actually recommended.
997 Bug 2S
MLindgren is offline   Reply With Quote
Old 07-27-2009, 09:55 PM   #50
dmk2
New User
I paid $279.66 at Momentum Porsche today for the two year service. It included an oil change and brake fluid change.
dmk2 is offline   Reply With Quote
Old 07-28-2009, 09:12 AM   #51
InTheAir
Patent Pending
InTheAir's Avatar
I know it's an old thread, but WTH, changing brake fluid is an easy DIY and cheap (power bleeder and fluid).
I just had 16000 service (they tried to sell the pollen filter and brake fluid, but I already did both myself), which was just oil. $189 with coupon.
InTheAir is offline   Reply With Quote
Old 07-28-2009, 10:11 AM   #52
Swoody
Swoody's Avatar
Absolutely...I just did my oil recently (posted in turbo forum w/ pics) and 2 days ago w/ power bleeder and Motul rbf600 did my brake fluid (super easy DIY). If any pics are needed or any questions LMK and I will post them.
2007 997TT, Carrara White, Terracotta/Black
Swoody is offline   Reply With Quote
Old 07-28-2009, 05:22 PM   #53
pbarch1
User
pbarch1's Avatar
Don't get me wrong I have no problem paying for "service" but the soaking that my dealer wants to give me was just too much. In todays economy I would think that dealerships would be looking to intice their regular customers in coming in for true service. If they told me they would check everythign for free, and charge me for what was recommended I would have probable paided the bill. That would have been service!!
pbarch1 is offline   Reply With Quote
Old 07-28-2009, 06:16 PM   #54
flintworks
User
Porsche recommends flushing the brake fluid every two years because the fluid naturally absorbs water which lowers the boiling point. Water also causes corrosion which can cause the brake lines to deteriorate over time. On 993s if you didn't flush the brake fluid it would turn into jelly but this was a different type of fluid. Some PCA and other groups that do track days require you to flush the brake fluid within 90 days of the event. If anyone is in the SF bay area I just opened the only Porsche factory certified indepent shop in the area. I'll do brake flushes for $75 and oil changes for $100. PM me for details.
flintworks is offline   Reply With Quote
Old 08-10-2009, 10:22 AM   #55
Spiffyjiff
Send a message via AIM to Spiffyjiff
anyone know a good shop in MD/VA? i live in gaithersburg so the closer the better.
2006 C2S
Xenon
Nav/Dension
Bose
Spiffyjiff is offline   Reply With Quote
Old 08-10-2009, 11:45 AM   #56
richc
User
richc's Avatar
Did the dealer tell you about flushing the cabin air and replacing it with alpine air imported from Austria? It was only $440 when I got it done and it made a huge difference in the driving experience. They can replace your tire air too, I was told they'll do that for only $300. I passed on the tire air change.
richc is offline   Reply With Quote
Tags
20000, 20k, 997, boxster, brake, cost, dealer, flush, jimmy, maintenance, michealscar, mile, motul, porsche, rbf600, sales, service, system
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
