Replacing stock shocks
2005 Carrera, tip, no PASM, 49+K miles, stock suspension, street use only. Four wheel alignment earlier this week at Johnson's Alignment in Torrance and was told a front shock was worn but not leaking yet. Dealer service said shocks not covered by warranty as they are a wear item.
Any recommendations whether to just get new OEM shocks, or replace all around with Bilstein HDs? It's my wife's daily driver, so PSS9s would be a total waste. Are the Bilstein HDs essentially the same a stock, or a noticeable improvement?
I was doing a search on Ebay yesterday for springs and ran across some OEM takeoffs for very reasonable price if you want to go that route.
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
Has anybody had to replace their stock 997 shocks with similar street shocks, or does everybody go with something for the track? Or is my car so much higher mileage than typical for a 997 at this point?
I've got 'em, I think!
Buy them from me! I've got all four shocks from my 2003 996 Cab4, plus sway bars if you want them, from when I put the X74 suspension on it when I had only 3000 miles on the car. Check with the dealer to see if they'll fit your car.
My car is gone, but the shocks are in my garage. How's $950 plus shipping sound? pm if interested.
Nick
Nick
The Bilstein HDs ride is a noticeable improvement, however, they are harsh compared to the ride smoothness of the OEM. IMO would only change the one going bad and not all fours.
Thank you - you're the first person who seems to know what the difference is!
At 49k miles the shocks are definitely worn even though only one may be "shot". The rears take the brunt of carrying the weight, while the fronts carry it under braking and turning. Considering that mileage I would replace all 4. At the very least replace the front 2 as the car will feel unbalanced with 1 new and 1 worn with 49k....
PS: What is the cost of OEM vs the Bilstein HD's?
I haven't talked to the dealer about cost. My regular service advisor was off last week. I also need to see what Sunset charges for the OEM shocks.
I have found tons of information on installing the PSS9s, but essentially nothing on replacement shocks, which is surprising, since so many 911s are only driven on the street
