Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 Forum
Old 05-18-2009, 09:29 PM   #1
autoboy70
User
autoboy70's Avatar
Default Knocking on 91
I just took my 997S in to check out the knocking that had been happening on occasion. It happens when I transition from enough throttle to maintain a cruise at 35-70mph (below 3000rpm) to moderate throttle. It seems to happen the most when I am cruising on the freeway and transition from a cruise to moderate acceleration. Like you were trying to accelerate a bit to get in front of the car beside you to change lanes.
It happens about 4 times on a 20 mile commute and sounds like faint, rapid pinging noise coming from the engine. You can feel it in the gas pedal. It can vary in length from a spit second to half a second.
I took the technician out for a drive hooked up to his computer and the car was running up to -9 degrees of retardation. I got it to make the noise a few times but everything checked out ok according to the computer.
They told me this was a "normal pinging noise" and sent me home with a washed car. Anyone have any experience with this?
autoboy70 is offline   Reply With Quote
Old 05-18-2009, 09:48 PM   #2
Sadiq
User
Send a message via AIM to Sadiq Send a message via MSN to Sadiq Send a message via Yahoo to Sadiq Send a message via Skype™ to Sadiq
"normal" and "pinging" in the same sentence? :-/ I bet microfiber was not involved in your car wash too
Sadiq is offline   Reply With Quote
Old 05-18-2009, 09:57 PM   #3
autoboy70
User
autoboy70's Avatar
Says it right here on the invoice. "Normal operation. Roadtested with customer to produce noise. This is a normal pinging noise."
Maybe it is normal for a 997.1 on 91 but it can't be good for the motor. It does it often enough that I am concerned. I'm headed to the Streets of Willow on the first of June and I wanted to make sure the car was in good working order. I'm sure I will be able to find some 100 octane to mix the 91 with before I get there but it is impractical to do that on a daily basis. I drive this car as a daily. My Subaru Outback isn't nearly as engaging.
Old 05-18-2009, 10:02 PM   #4
Edgy01
Poseur
Edgy01's Avatar
You're probably in California where you get to pay more for an inferior grade of "premium." So long as California permits 91 to be considered premium we'll have that problem. The anti-knock sensors in these engines are supposedly reactive to the pinging and retard the ignition in near-realtime to reduce the impact to the engine mechanicals.
Dan
06 997S PCCB Hard-Top Cabrio
Turq. Blue, Nat. Brn Leather
http://www.rennteam.com/photopost/sh...00&ppuser=8756
Edgy01 is offline   Reply With Quote
Old 05-18-2009, 10:08 PM   #5
autoboy70
User
autoboy70's Avatar
So knocking is normal like male pattern baldness is normal. They're both big problems but we have to learn to accept the hand we are dealt.
Old 05-18-2009, 11:24 PM   #6
MJones
MJones's Avatar
Interesting and rare problem, which I've never experienced in my previous Carrera S or my current GT3, even with 90 octane, the best I could get at times on a road trip.
Have you tried switching the brand of gas you are filling up with?
They have 100 available at Willow BTW
'10
MJones is offline   Reply With Quote
Old 05-18-2009, 11:44 PM   #7
JFA65
User
JFA65's Avatar
Only 91 octane available in my area and no pinging on my 09 S with 3600 miles and track time.
JFA65 is offline   Reply With Quote
Old 05-18-2009, 11:55 PM   #8
nyca
User
didn't Arnold just sign that new law for "low carbon" gasoline for California? If you think the crap they are mandating now is bad, just wait a couple of years.
nyca is offline   Reply With Quote
Old 05-18-2009, 11:58 PM   #9
Hockeyman11385
User
Hockeyman11385's Avatar
You can buy octane booster that will help. I've used it on a Scuderia that will only run on 93 and it works just fine. I found that one bottle of octane booster per 1/2 tank will do wonders.
Hockeyman11385 is offline   Reply With Quote
Old 05-19-2009, 12:10 AM   #10
helispud
helispud's Avatar
Our premium in this area is 91 octane. I've never noticed any pinging but then we are at 4000 + feet elevation. Our regular gas is 85 and my Toyota Tundra pickup pings and sometimes knocks on it under high load-low rpm conditions.
It surprises me that they sell 91 as premium at low-elevation parts of CA. Even in Boise at around 3000
feet most premium is 93.
2007 Artic Silver Carrera
Stone Grey Full Leather
Heated Power Seats
Bi-Xenon Headlights
Self Dimming Mirrors
Sport Chrono
Bose Sound
helispud is offline   Reply With Quote
Old 05-19-2009, 01:47 AM   #11
sharkster
sharkster's Avatar
Send a message via AIM to sharkster
I'd stick to running gas from 76 or Chevron.. the other stations' 91 isn't as good that's for sure. You're in Los Altos and there's a VP station right near you so you can grab a few gallons of 100 to mix in when you like
Alex "Sharky" Ross
www.sharkwerks.com
The Porsche Performance Center for EVOMS, TechArt, HRE, Tubi
Phone: 510-651-0300
Email: sharky@sharkwerks.com
2010 997 GT3 SharkWerks Project
2009 997S Sharkwerks ZTADPOL
2007 997GT3 RS SharkWerks ZKERMIT
2006 Cayman S SharkWerks RS350
sharkster is offline   Reply With Quote
Old 05-19-2009, 02:54 AM   #12
Macster
User
Default 9 degs. retardation can be normal. Timing quite dynamic....
and depending upon when you look at timing data it can be retarded or quite advanced.
Part throttle load most likely to result in pinging which is not detonation which is what the knock sensors are tuned to "hear".
Do not know what gas you've been using but I've found name brand -- Chevron, Shell, Union 76 -- gasolines the best. Stay the heck away from Arco and Valero and other off brand stations.
Buy from a busy station.
Engine might be due a dose/treatment of Techron. Maybe two bottles, used according to instructions. Follow with an oil/filter service.
Engine deposits can accumulate and interfere with air/gas flow into combustion chamber and this produces improper combustion. Deposits in combustion chamber can also cause pre-ignition and pinging.
Be aware of racing gas. While it is high octane to be sure due to its cost and low demand it can be quite old. High octane gas goes stale quite fast and if you buy it you'll be getting expensive gas that may be hardly much better than fresh 91 octane.
If you can reproduce symptom if you want to test something dump a bottle of Swepco 503 gas fuel treatment in tank.
http://www.swepcousa.com/lubesite/lubepdf/j03856.pdf
If symptom goes away....
If not give the Techron a try.
Also, I notice my car runs much better after a 50 or so mile drive. Even my daily 30 mile commute -- most freeway but 5 or 6 miles city streets -- not the same as legal but high speed (highway speed) "blast" non-stop.
Sincerely,
Macster.
Macster is offline   Reply With Quote
Old 05-19-2009, 05:21 PM   #13
dasams
User
dasams's Avatar
Quote:
Sorry, but you're misinformed. All gasolines in the future (inc NY) will contain increasing amounts of renewable carbon as opposed to fossil carbon. A fuel's octane rating can't tell the difference. dave
dasams is offline   Reply With Quote
Old 05-19-2009, 05:35 PM   #14
dasams
User
dasams's Avatar
Quote:
Buying from the majors can make a difference but may also be a waste of money. Neither Valero nor Arco are 'off' brands.
The one variable that no one's addressed is that the posted octane rating is the ave of the 'motor' and 'research' values. You want a fuel with the highest MON which, for example, could test as 86 MON and 96 RON (= 91 ave). You do not want a fuel that is 82 MON and 100 RON because it won't perform well under load. Search 'octane rating' at wiki for a brief explanation.
Experiment with different gas stations and you might find a winner. dave
Old 05-19-2009, 06:31 PM   #15
Macster
User
Default By off I was referring to my recollection neither station offered...
Top Tier gas.
Link not working so I can't look this up but IIRC neither Arco or Valero offer top tier gas. This what I meant by off.
Valero's claim to fame is it has refineries capable of refining worst crude stocks for gas and diesel.
Arco just has inexpensive gas as its claim to fame as long as you pay cash. Pay ATM (credit cards not accepted at pumps IIRC) and it is not even inexpensive. My seat of the pants dyno has it labeled cheap gas though. Car does not like Arco gas.
Tried it a few times when gas prices were at their highest and vowed never again.
Your suggestion about trying diff. gas stations could be a solution.
However, I've consistently found Chevron and Shell stations have best gas in my area (bay area).
Sometimes after I've run a tank that I purchased at say Rotten Robbie or USA Gas station -- cause other station not handy and I was pressed for time and needed to just get some gas in car -- then fill up with a tank of Chevron or Shell engine acts like it is young again.
Improvement noticable.
Sincerely,
MarcW.
Tags
knocking, throttle
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
