Spark Plugs
Old 11-01-2015, 03:52 PM
tomc66
tomc66's Avatar
Default Spark Plugs
What can I expect to pay to have the spark plugs changed in my 2011 911 4S?
Old 11-01-2015, 05:33 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,410 Likes on 855 Posts
2009 C2S
$50 if you do it yourself. I've done it twice now at 40K and 80K miles. Never had the dealer do it.
https://rennlist.com/forums/997-foru...-plug-diy.html
Peace
Bruce in Philly
Old 11-01-2015, 06:05 PM
cerbomark
cerbomark's Avatar
$700... at dealer.
Did it myself for less than $100. Priceless!
Old 11-01-2015, 06:20 PM
NAM VET
NAM VET's Avatar
best to have a friend help with removing the rear bumper cover, and order a few spare push pins incase you break one or two. Have an assortment of 1/4 inch drive tools. Have a good 3/8 torque wrench. My son and I did hour prior 997S in about 2.5 hours. One plug on each side are a bit of a chore because of a muffler bracket giving scant clearance.
If your muffler connectors and bolts are rusty, order new ones, on our no salt exposure car everything came off easy as pie.
Easy if you take your time.
all the best....
Old 11-01-2015, 09:45 PM
Bruce In Philly
all the best....
Good points, but on the 997.2, you won't have problems with the muffler brackets if you remove the bumper. Mine were totally fine at 80K miles. Now the three evil bolts at the cat... well you have a high-probability they will torque right off so yes, get six spares if you choose to leave your bumper on and therefore have to remove those evil three ... make them stainless.
Also on the 997.2, that rear plug is not so bad.
Peace
Bruce in Philly
Old 11-02-2015, 11:46 AM
Ibanezgod
Ibanezgod's Avatar
wish the turbo was that easy!
Old 11-02-2015, 01:27 PM
Petza914
Petza914's Avatar
Received 6,140 Likes on 3,913 Posts
I just did the plugs and coil packs on my wife's 997.1 C2S. Removed rear wheels but nothing else. The heat shields will come out sliding them toward the front of the car and angling them a bit. The .2 might be different.
Old 11-02-2015, 01:35 PM
andy92782
andy92782's Avatar
I did the plugs myself on my 997.2. Plenty of write-ups on this forum on how to do so. The procedure is straightforward and not difficult with the proper tools. Save yourself $500 and "get to know" your 997.2 at an intimate level.
Old 11-02-2015, 01:59 PM
cerbomark
cerbomark's Avatar
Wow.. Heard the .2 is easier than the .1....Wonder if we are taking down mufflers for no reason?
Old 11-02-2015, 02:34 PM
Bruce In Philly
I've done the plugs twice now on my 2009 C2S 997.2 I simply could not do it without removal of the mufflers. But then again, I am a flaming amateur.
Peace
Bruce in Philly
Old 11-03-2015, 03:17 PM
FFSstavros
FFSstavros's Avatar
Pete, can you point me to the DIY you used for the 997.1? I also have a C2S and am just short of the 40k mileage mark.
Old 11-03-2015, 03:26 PM
Petza914
Petza914's Avatar
I probably used a DIY guide when I did these the first time in my car a couple years ago, but having done the job before, didn't use a DIY this time; just grabbed the plug and coil fastener torque values from the torque value list I created and add to as I do various DIYs.
I'd be surprised if there's not one at the top of the 997 Forum list in the DIY index though.
Old 11-03-2015, 04:04 PM
Petza914
Petza914's Avatar
I'll share a tip though. I used 2 short 3/8" extensions which makes the job much easier as there's enough space to slip the spark plug socket with the first short extension on it into the plug tube and then while holding the end of that first one connect the second short extension on, and then connect the ratchet handle or torque wrench. The clearance directly behind the plug access tubes is limited and you can't get a single longer extension into some of the holes. Being able to do it in two segments solves that issue and then gives you the perfect length extension for the ratchet end to be just outside the tubes. Hand start all plugs as you're re-installing them.
Quick Reply: Spark Plugs
