Don't both visors have the lights? (I always had the leather visors, so that's all I know).
My leather (no tag) replacements both had lights. Also, I've done this to 3-911's and the easiest way to get the visors out of the car to work on is to slide them off the arm - a firm, steady straight pull (be careful not to bend the arm) worked every time. Didn't have to worry about breaking those pesky plastic tabs on the mounting bracket cover.
Here is the link to the ebay Item number: 130339635261 for cover-up decals , which are only $15 for a set of two and, in my opinion, is the safest and best solution .
Nothing unsafe about what I did at all. It may be the easiest solution though; but only covers the mirrors unless your interior is black and $31 for that. The irony is that the mirror side is the easiest to remove.
I like the leather idea though - would look nice and perhaps have some aroma. I may do those and a cc at some point...when I get bored.
Please clarify: How do you remove the sun visors that have lights?
If "yanking" seems a little crude or they don't want to budge (like mine), see my post about removing them with a torx-25 driver - not hard at all. Use a trim tool or a credit card to remove the trim cover and reveal the screw.
