Warranty claim, cracked Carbon Steering Wheel
Old 11-06-2009, 11:14 AM
Bruce R
Bruce R's Avatar
Default Warranty claim, cracked Carbon Steering Wheel
What’s the consensus? Should I put in a Warranty Claim for this cracked steering wheel, you cannot see the crack from the driver’s seat but can feel it.
Or am I being pedantic? My concern is that it grows.
Actually I’ve see a crack like this before on a fellow PCA members 993 wheel. It seems that carbon is very susceptible to sun damage and is brittle. Good luck M3 coupe owners with your carbon roofs!
Old 11-06-2009, 11:23 AM
CBejbl
CBejbl's Avatar
I probably would put it on the record. Chances are the crack will continue to migrate.
Old 11-06-2009, 11:25 AM
Hauser_III
Hauser_III's Avatar
Definitely put in a warranty claim. It's defective, and should be replaced.
Old 11-06-2009, 11:27 AM
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Report it to the dealer... don't wait.
Old 11-06-2009, 11:37 AM
richc
richc's Avatar
Get it fixed. You don't want that thing splitting and inserting a carbon splinter in your hand.
Old 11-06-2009, 12:12 PM
soverystout
soverystout's Avatar
Definately report it. Once replaced, I would get a cover for the wheel for use when you are not driving it.
Old 11-06-2009, 01:03 PM
rvklein
rvklein's Avatar
My 996 had a cracked carbon steering wheel too. I think it's fairly common.
Old 11-06-2009, 01:08 PM
PHDX2
PHDX2's Avatar
Definitely file a warranty claim.
Old 11-06-2009, 01:17 PM
points
points's Avatar
Ask to replace it with wood. Probably around the same price and looks better.
Old 11-06-2009, 01:26 PM
todd.
todd.'s Avatar
Absolutely, that's why you have a warranty, get it replaced before the money comes out of your pocket.
It's always a good idea to get any questionable warranty issues dealt with prior to the warranty ending.
Old 11-06-2009, 01:27 PM
OCBen
OCBen's Avatar
This has nothing to do with carbon fibers being susceptible to sun damage or in being brittle. And, no, you won't get carbon splinters either. This woven carbon-fiber material is very soft to the touch and silk like in handling quality. It is used in this application strictly as a cosmetic covering over the steel rim of the wheel and other items such as the handbrake and gear shift lever to give a unique look.
It's the acrylic plastic coating that is failing here, and warrants steering wheel replacement under warranty.
Old 11-06-2009, 01:29 PM
OCBen
OCBen's Avatar
Hey Pat, is there a plastic coating on the wood trim here like Mercedes uses?
Old 11-06-2009, 01:50 PM
Edgy01
Poseur
Edgy01's Avatar
You should submit it for replacement. I would almost consider it a safety issue, in that it can cut up your hands in no time.
If there is a coating on the wood I sure don't see that it's much of anything. I have the same wheel as points. Love it.
Old 11-06-2009, 01:52 PM
points
points's Avatar
Not that I notice....that shiny look is a furniture oil applied very lightly to every bit of wood but the steering wheel.
Old 11-06-2009, 02:22 PM
OCBen
OCBen's Avatar
That dark makassar wood trim looks really good. Definitely will consider it next time.
Quick Reply: Warranty claim, cracked Carbon Steering Wheel
