classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
User
I haven't seen any posts like this, but my 997.2 C2S gave me a warning to add air, 5lbs in the front and 7 in the rear. Wow, that's amazing!
#2 |
Poseur
Rennlist Member Join Date: Nov 2005
When it tells you that you need to take a closer look. Those amounts of air just don't disappear overnight unless you have some sort of issue. The most I ever notice over time is perhaps 2 lbs. But when 7 is missing in a rear--you have a slow leak which tells me "nail."
Dan 06 997S PCCB Hard-Top Cabrio Turq. Blue, Nat. Brn Leather http://www.rennteam.com/photopost/sh...00&ppuser=8756 |
#3 |
User
could be temperature drop, tire pressure changed? but best to check out with tire shop, one time I had 3 nails in my rear left tire.
#4 |
User
it could be the cold...but I am taking it to the tire shop in the morning just for a check. Running pressures are 30 on the front and 37 in the rear according to the tpms.
#5 |
Rennlist Member Join Date: Mar 2004
I bet that's that.
"Dream as impractical, irrational and unnecessary as that may be... Here's to the Dreamers!" -- Porsche AG |
#6 | |
Banned For Life....
Rennlist Member Join Date: Feb 2005
Quote:
I like to run my fronts at 30 but now that we've had a few days in the 30s-40s, the cold pressure drops to 27 which sometimes triggers the "add air" thing.
Coochas aka Dave |-Cayenne TitS Ed Purrrr Red|-'99 Boxster Black| -'09 997 TT RS Orange -Check out my p-car e-brochure collection -997 Emergency Procedures Mobile Website |
#7 | |
Rennlist Member Join Date: Nov 2002
Quote:
I don't know the Turbo pressures off hand but on a 997 S that is too low (street or track). Ideal is F (32-34)--R(38-40) @68F. These pressures hold no matter the application, street or track; and the 8lb spread is enough to play with over/understeer for your preference(s); and if that is really not enough you could stretch another 2 lbs in the rear (but not the front). You can run track tires at lower pressures, but theoretically and practically you go up in pressure on street tires at the track, and this is recommended by most experts and set up specialists. However, the fully loaded pressures 37/44 cause too much understeer, so those pressures are outside the envelope, except for fully loaded street driving. I have long been amazed at the amount of fiddling people do with tires (at the track and autocross... maybe it is a "good luck charm"). When you ask the "set up" guys why people do it on street tires..you generally just get a big smile and a shrug.
![]() Never argue with idiots - first they drag you down to their level, then they beat you with experience. *********************** Sponsored by: Póg mo thóin Adventures |
#8 | |
Banned For Life....
Quote:
I prefer my tires with lower pressure on the street and like the softer ride that they afford. I think this helps a lot around here with all the bumps and potholes. Performance wise on the street they're just not a factor as I'm never near the limit! They also go up about 4 psi just during my short commutes. I also ran my pressures on the lower side with my C4S. Never had a problem with any summer tire in 5 years....I think the tires are happier like this!
#9 | |
Quote:
On a Summer day a tire needs less air than on a Winter day to reach a given pressure (PV=nRT), therefore a tire set on a Summer day (morning temp 68F) will be somewhat deflated on a cooler Fall 40F morning. I think this is what the OP observed.
#10 | |
Quote:
#11 |
Lifetime Rennlist Member Join Date: Jun 2003
Dont get too excited about this. The dang things can be a pain in the arse. If say for conversation the
pressure goes below 30lbs to 29, it goes off because the other tire is 30 lbs. They are only 1 lb off but you get that annoying lite and it stays on till you fix it even if the temp goes up and the pressure goes up. You have to put air up to like 35 or 40 to get the light off and now you have 40 in the right front and 30 in the left front. ALOT Of guys in the GT3 community went to Porsche and had the dealer disable it.
OG 997 09 C2S PDK Carrera White Rennlist member# 030815-4002 Official NRA Liason to Sierra Club HWFMR paulgt3@gmail.com 2008 BMW 335i (wifey's) 2006 BMW X5 4.8iS 04 GT3 RSR Le Mans entrant Gone 97 993 TT midnite blue/cashmere(missed) 04 RED 996 GT3 2007 GT sliver GT3 2009 AMG C63 |
#12 |
User
well, i really think it is the cold. it's been about 40 here in the morning and 70 in the afternoon. but, it gave me the warning yesterday afternoon as well. It was even pressure on all 4 corners, 5 each in the front and 7 in each rear. I will have them put in the recommend running pressures and see what happens. If it does it every morning when it's cold, that would be annoying!
#13 | |
User
Quote:
#14 |
Rennlist Member Join Date: Mar 2002
Paul's got it right... anyone taking their 997 GT3 to the track knows about the dreaded TPMS. IIRC.. the variance is 6 or 7 pounds?
Lesile... would you rather have your car or a significant other remind you?
Craig `95 C2 - GR/Blk ABD/LSD, Brembo Big Reds, GHL, Bilstein HD's, H&R springs, Euro Turbo sways, GIAC chip, AJUSA strut brace, corner balanced, JMH pedals, split grill, turbo S ducts, HID's, BK harness bar, Schroth harnesses, Recaro Sport Toplines `05 955 S - Blk/Blk Out `06 997 C2S Blk/Blk `87 Cab - GP Wht/Blue - (Gone not forgotten) PCA - INWR RL Member #000314-1823 |
#15 | |
Quote:
If you have the dealer do that, you must leave the car there to cool down before they fill the tires. I suggest you do it yourself in the comfort of your garage with an inexpensive compressor.
| Thread Tools | |
