End to the oil change after break-in debate
#106
Still plays with cars.
Mac, so much for my hypothesis. Sounds like the idea of not worrying about replacements during the warranty period is the right one
#107
FWIW, I reject both explanations. Rather, I think that increasing intervals are more a function of improvements in synthetic oils. (Audi, for instance, used to offer free maintenance in the early part of the decade, then they stopped offering free maintenance in the middle part of the decade. The frequency of recommended services didn't increase when they stopped offering the free maintenance.)
I don't think increasing the frequency of service intervals in a street car does anything other than increase maintenance costs and waste time. There's no evidence of increased engine, transmission life with additional fluid changes. Even if an engine or transmission fails at 100K miles, it still leaves a bad taste in the mouth of owner of the car at that time and isn't likely to build brand loyalty. If additional fluid changes markedly reduced the chances of such failure, I'd fully expect a manufacturer to recommend additional changes. Intentionally built in obsolescence wouldn't appear to be a good approach to making big ticket durable goods.
#108
The above is the rub. All manufacturers internally have decided upon a minimum "useful life" for their products. The components composing the product are engineered to last 'at least' that long. If they last longer, fine. But the goal is to set the warranty period sufficiently short of the useful life so as not to risk too much capital under the same. Remember 'warranty' is part marketing (with the other part being legal) as no manufacturer would give one (and swallow its attendant costs) if the other guy wasn't.
What has separated Porsche from other car manufacturers is that its historical view of its product's "service life" was very similar to its customers: The company 'philosophy' was to engineer/build a performance product with a long useful life. Some of the push back by Porsche owners recently deals with the fact that the company seems to have strayed from its historical view and moved toward a more mainstream manufacturer view of product useful life. For example, there is presently a thread on the 997Turbo Forum re Porsche's movement from the trusted GT1 block to the new A91 block with this very issue at its core, imho.
Put a gun to my head and say "call it", and I think that Porsche's current servicing intervals are too long for buy and hold enthusiasts that use their cars; but fits perfectly for those who do not use them (garage queens) or those that turn over their cars every few years (whether buying or leasing). The cynic in me says that Porsche has studied its customer base here and is simply playing the statistical averages as to owner types ...
#109
I suspect geography and associated marketing plans are a factor. I wonder for instance if the oil change intervals are different in Europe than they are here. Is it possible that German manufacturers base themselves on real data gathered from the target market? It would make sense.
That is a big reason that pushed me to get oil analysis on my cars, to help me define what the interval really should be for each of their applications/usage.
Every analysis report, no matter how each car is used, has come back short of the broad recomendation for the masses.
#110
It would be absurd for them to make this recommendation without knowing beforehand how it will play out in the long run - the useful life of an engine.
#111
Ben,
I think the point is what the manufacturer has decided is the "useful life" of the engine. If say, 100,000 miles then longer oil change intervals may have little effect. For the guy who wants to eek out 200,000 miles, perhaps it makes a difference?
#112
From what I've found synths almost double what mineral can do, no matter how extreme or how they are used. The constant for both, the harder you use them the sooner they breakdown and need to be replaced
The trick is finding what frequency works best for a motor's specific application.
#113
But wasn't Toyota bragging in their commercials about their engines lasting a million miles, the so-called Million Mile Club?
Saab had a campaign (don't know if they still do) where they give a free car to any owner who achieves a million miles on the original engine!
http://www.autoblog.com/2006/12/18/s...ion-mile-club/
So I'm guessing the useful life of an engine, from a manufacturer's perspective, would be closer to 500,000 miles than to 100k. So I'll guess 300k. I know I had over 300k miles on my 300ZX on the original engine, and I abused that car, not babying it all.
#114
The downside I see of new low maintenance cars is that maintenance costs outside of warranty could exceed the incentive to own a older car of that brand. If no one wants to own a prestigious higher mileage car, then resale drops. If resale drops, new cars won't hold their value and depreciate even faster when you drive them off the lot.
#115
How could it ever be harmful to have clean oil in the engine at all times?
As a sanity check, view the oil circulation system as an open system instead of a closed system. Meaning fresh oil flows into the engine (after being preheated to engine temp) flows through all the components and flows out the engine, taking away all the byproducts of combustion and all the accumulated debris along with it. That would be the ideal oil circulation system in the abstract.
#116
Saab upped their intervals to 10K - funny they stopped the million mile giveaway. How odd....
#117
A link will suffice.
If you had bothered to read the article you would have learned that it was a one time offer in 2007. It had nothing to do with their engines not living up to this standard, as your comment implies.
In order to qualify for the prize, an owner must proivde verifiable proof that he or she is the original owner of the Saab in question, that the vehicle's in running condition (Saab may want to be a bit more specific on that point), that the odometer hasn't been tampered with and that it has always been registered in the U.S. Once all those boxes are checked, said Saab owner will get his or her own brand new 2007 9-5 Aero. This offer, if that's what you want to call it, will run from now until the end of 2007, after which they'll go back to giving members of the Million Mile Club a hearty hand shake. If you're Saab is at 950,000 miles or so, we'd suggest a nice long road trip next summer.
#118
I changed my oil today, 2550 miles. I did it because I thought it was a good idea since I do too many short trips. You can see the filter was dark but not black. I tried to get a pic of the oil left in the housing, did not come out too well.
My biggest challenge is my drain pan fit under the oil pan but with no clearance for me to undo the drain bolt so I had to jack the car undo the bolt and then let the car down. It takes a loooooooooong time for the oil to drain. Also you need to press the filter down into the housing, the opening will look smaller than the one you are removing because it opens as you fit it in.
Our 2006 CR-V calls for oil changes every 5k miles.
After this I will probably go back to 1x/year.
