coolant low really low!!! burning?
Poseur
80% of the time it is the cap, alone, causing the problems. I learned on Rennlist years ago about the problems with these silly caps, and for several years the dealership simply blew it off, never bothering to replace the cap. They finally did after much prodding--and it solved the problem of always having a low level on the coolant.
Those that do the above on a regular basis like just distilled water and water wetter cause if a coolant leak develops it is not as dangerous with just water/water wetter as it is with anti-freeze.
There was a post or two on the GT2/GT3 sections about guys losing the car when a coolant line fitting broke and dumped coolant on the car's tire or in one case dumped coolant on the track and a following car hit the stuff and the driver lost control and the accident killed a ride along instructor.
But you'll have to check with the most restrictive track you visit and see what's required and go with that.
I don't know how well water and water wetter protects the engine cooling system aganst freezing so you'll have to consider if you drive year 'round to after track season ends switching back to anti-freeze/water. Also, I'm not sure how well water and water wetter is for the pump seals.
Sincerely,
Macster.
On my 09 I had a very slight coolant leak that I only noticed :1) because the level went down slowly and 2) when changing the oil, I noticed a few drops of coolant collected on the bottom of the engine near the point of 'dripping off'.
The problem in my case was a gasket in/around the water pump that was faulty. That fix required the dealer to pull a lot of stuff off to get to the and replace that $1 part.
I just ran into the same issue today. I was driving to work, and all of a sudden the low coolant warning light went off (to my surprise). I just had the car topped off 3K miles ago when I was in for an oil change. I'm going to check the top after work to see if there is any residue/deposits. Hopefully this will be the culprit. The first thought that ran though my mind was head gasket which would be a nightmare. I hope this is not the case, because overall the car runs strong. Unfortunately, my car is just out of warranty with 32K miles and all expenses will be borne by me.
Jay
