Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 08-25-2010, 05:39 PM   #1
Alfaguy2
User
Alfaguy2's Avatar
Question How long to let oil drain out?
Just changing my oil/filter in the 911 in advance of a long trip in it on Friday. I notice that this engine keeps dribbling oil for hours unlike most of my other cars.
The oil was well warmed up before draining but even still it keeps on coming. Have to leave it dribble away overnight now as it got too dark to complete the job.
Just wondering how long you DIY mechanics leave the oil drain for?
To remove this ad, register today or login if you already are registered!
Alfaguy2 is offline   Reply With Quote
Old 08-25-2010, 05:57 PM   #2
ADias
Super User
ADias's Avatar
I do not think that a little oil remnant matters.
ADias is offline   Reply With Quote
Old 08-25-2010, 05:58 PM   #3
Dave R.
Dave R.'s Avatar
15-20 minutes
Dave R. is offline   Reply With Quote
Old 08-25-2010, 06:57 PM   #4
Mike in CA
Mike in CA's Avatar
If you're talking about a 997.2 make sure you loosen the top mounted oil filter before reinstalling the drain plug, otherwise a fair quantity of dirty oil will remain trapped in the engine. Not doing so could account for the "dribbling oil for hours" that you mention. Once you've loosened the filter, 15 minutes or so to drain would be plenty.
Mike
2014 991 GT3
2011 Cayenne S
2011 Audi A3 TDI
Mike in CA is offline   Reply With Quote
Old 08-25-2010, 07:16 PM   #5
rijowysock
rijowysock's Avatar
Send a message via AIM to rijowysock
they let mine drip for about an hour. (they were doing other things as well, and just left it while they messed around) it was still dripping steadily after the hour.. but he said it didnt matter.
rijowysock is offline   Reply With Quote
Old 08-25-2010, 07:57 PM   #6
f4 plt
f4 plt's Avatar
Porsche recommends as some have already said, that you remove the oil filler cap to allow air in. Also slightly loosen the oil filter cover to allow the oil to drain out of that cavity. They also recommend you allow the engine to drain for an hour. If you drain the old oil for less time, when you add oil only add 8 quarts and check the oil level then top off if necessary. The above is for a 997.2 3.8 liter engine.
f4 plt is offline   Reply With Quote
Old 08-25-2010, 08:07 PM   #7
VGM911
User
Drain time is somewhat shortened if the oil is warm (not hot).
VGM911 is offline   Reply With Quote
Old 08-25-2010, 08:22 PM   #8
gray911
User
gray911's Avatar
I just changed my oil and let i drain for 2 hours. It still constanly drips. I tilted the car on the left and more oil came out.
gray911 is offline   Reply With Quote
Old 08-26-2010, 12:45 AM   #9
VGM911
User
I've also read that once you think most of the oil is out, you should crank the engine for a very short bit to drive remaining oil to the pan/sump from the cylinders, etc.
Old 08-26-2010, 01:12 AM   #10
acao
acao's Avatar
As long as it takes for me to tackle everything else.
I drain the oil first. While that's flowing, I change the engine and cabin filters, clean the throttle butterfly, clean the MAF, reset the service indicator, check hoses and belts, install the new oil filter, wipe down the airbox, and take care of any other projects I had planned (brakes, plugs, etc.). I lower the car (carefully), put the plug back in, and fill the oil. With the annual maintanence check list, it's about an hour.
acao is offline   Reply With Quote
Old 08-26-2010, 01:39 AM   #11
mooty
mooty's Avatar
i run the motor hot.
drain for 20 min.
i need to dump in 9 qts
996gt3 and 97gt3
BBS CL 18" new wheels $5000
OZ CL 18" used wheel $1000
OEM CL 997.1 GT3 wheels satin blk $1800
20' cheap not so nice enclosed trailer for sale, does the job.
Fletcher Jones PORSCHE: official supplier of mooty RS's
SCHNEIDER NELSON PORSCHE: top grade
CARLSEN PORSCHE: unscrupulous, now 3x, i gave them another chance.... fail....ugh
PCA National Instructor
Rennlist Member #021125-3378
mooty is offline   Reply With Quote
Old 08-26-2010, 04:53 AM   #12
Macster
When engine and oil hot and most of the time it is cause I drive to the office and do the oil change in the shipping area I let the oil drain only as long as the oil stream remains unbroken. Just a few minutes.
I'm under the car with a flash light looking at things and I don't want to expend the effort to get up from under the car then get back down again.
I have everything already laid out so once down and under the car I don't have to get up again if I don't want to.
If you let the oil drain another hour I doubt you'd get more than another teacup's worth of oil from the engine.
There's probably another 2 quarts of oil maybe a bit more in the engine that'll never drain out so another cup or so isn't worth the extra drain time, unless you've got the time to watch to oil drip drip drip drip out of the engine.
I don't.
Sincerely,
Macster.
Macster is offline   Reply With Quote
Old 08-26-2010, 12:24 PM   #13
Quadcammer
That 5oz or less of oil that comes out is completely inconsequential.
Drain the bulk, let it drip for a few minutes, and seal it up.
Not a member, must be a mistake
Quadcammer is offline   Reply With Quote
Old 08-26-2010, 01:32 PM   #14
cbzzoom
User
Quote:
I sure hope you didn't trick anyone into doing this!
cbzzoom is offline   Reply With Quote
Old 08-26-2010, 02:01 PM   #15
Edgy01
Poseur
Edgy01's Avatar
Don't even suggest to people that they consider cranking an engine that you have drained of oil. (Someone may take you seriously). I'm sorry, but this entire topic is ridiculous, if I many be so blunt. Open up the drain(s) holes, drain the oil, and within 5-10 minutes max just close things up and refill it. You get absolutely nothing by wasting your time letting it go any longer.
Dan
06 997S PCCB Hard-Top Cabrio
Turq. Blue, Nat. Brn Leather, and loaded!
Edgy01 is offline   Reply With Quote
Paid Advertisement
Tags
2009, 993, change, diy, drain, drainin, filter, highlander, indicator, long, oil, overnight, reset, service, toyota, wait
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
