DIY On Porsche OEM Satellite Radio Install
Old 10-03-2010, 01:39 AM
Musclehedz101
Musclehedz101's Avatar
Thumbs up DIY On Porsche OEM Satellite Radio Install
Hello All,
A few months ago I completed my Porsche OEM Sirius Satellite Radio install in my 07' 997 C4S Cab. With Work and summer family vacations I put off writing my install up in a DIY and just got around to completing it.
A big thank you to Ric at Suncoast for all of his help.
As the doc it too larger (due to pictures) I have posted it for download (for free, just wait it out for a few seconds) at the following site:
Download DIY Link:
http://rapidshare.com/files/42279771...io_Install.pdf
Regards,
David
Old 10-03-2010, 02:04 AM
docfink
docfink's Avatar
Thanks for offering the link, but even with the "slow download" free link doesn't work. I'll try again, but can you confirm it's a functioning link?
Old 10-03-2010, 02:32 AM
Musclehedz101
I just tested the link using a different browser (Safari) by copy/pasting URL into browser. The site came up then I clicked on "Slow Download", waited the 25 seconds & the document proceeded to download.
If you continue to have issues, PM me with an email address to send you doc.
Regards,
David
Old 10-04-2010, 01:25 AM
KeninBlaine
KeninBlaine's Avatar
The download worked fine for me. Thanks for the excellent writeup. I'm curious what the Sirius tuner sells for. I have a GW500 installed in place of my CD changer (which I removed). Would this present a challenge to add the Sirius tuner now?
Old 10-04-2010, 12:29 PM
Musclehedz101
Hello,
Thank you for the feedback on the doc, just giving back to the forum after all the vauleable info I have gathered here myself.
Give a RIC a call at Suncost (no affiliation, just great service/support) and he can quote you on the two Porsche parts I listed in Doc, as that is all you should need from Porsche. All parts required are on first page of my doc.
You shouldn't have any issue with having a GW500 w/out CD Changer, as you can see from my doc, my MOST loop setup is as follows:
PCM -=>Tooki BT -=> GW500 w/ Changer -=>Sirius Tuner -=>Nav -=>Bose
One disclaimer... The method I documented is what I found (after ALLOT of "trial & error", part swaps, you name it) worked for my car/setup. "Your mileage may vary"..
With all the guess work done, the install so go very quickly.
BTW, if you do decide to do the project, at time of service activation, call Sirius and tell them you just bought the system through Porsche and wish to activate your three month FREE subscription service!
Enjoy!
Old 07-26-2012, 12:46 PM
lic265
lic265's Avatar
I have a question about adding the new Gateway 500 with the OEM sat radio module in my 07 997 TT with PCM and No c/d changer.
It is not clear where to add what components in the MOST circle.
Here is the link to the Denison instruction manual - http://http://www.dension.com/sites/...tall_guide.pdf
Any advice would be welcome !
Old 07-26-2012, 01:09 PM
USMC_DS1
USMC_DS1's Avatar
David, great write up(very detailed) and in PDF format even... thanks for sharing with everyone. I'll add your posting to my DIY Index Post. BTW, the file downloaded in 2 secs from Firefox.
Old 07-27-2012, 02:31 PM
Musclehedz101
What I found was the order that worked for me was:
1) PCM
2) Tooki BT (This was later, added AFTER Denison my initial install, so you should be ok without it)
3) Denison/CDC
4) OEM Sirius Sat. Radio
5) Nav
6) Bose AMP
As I had already a CDC, programing via PWIS was not required in my case.
Hope this helps.
Old 01-03-2013, 12:11 AM
Musclehedz101
If RapidShare link no longer works doe Doc download then try downloading from my Dropbox account:
https://dl.dropbox.com/u/82906075/DI...io_Install.pdf
Old 01-03-2013, 09:15 PM
Thundermoose
Thundermoose's Avatar
I couldn't get this link to work either.
Old 01-04-2013, 01:58 AM
vladeden
vladeden's Avatar
Hey guys doesn't this Audi OEM Sirius receiver look identical to the Cayenne receiver ?
Both made by Delphi. Wonder if compatible?
Here is the link from Ebay:
http://www.ebay.com/itm/Sirius-XM-Ra...f90fae&vxp=mtr
Old 01-04-2013, 01:14 PM
Musclehedz101
Sorta' looks like it but no idea if compatible...
Old 01-04-2013, 01:15 PM
Musclehedz101
Dropbox Link (Tested and verfiied) for PDF on DIY "How To"...
Old 01-04-2013, 05:48 PM
Thundermoose
Worked for me - thanks! Great write-up!
Old 07-07-2017, 10:44 PM
TV911
TV911's Avatar
Does anyone have a working link to this guide? Thanks!
Quick Reply: DIY On Porsche OEM Satellite Radio Install
