Loose side marker - please help
Old 11-28-2010, 12:30 PM
403portside
403portside's Avatar
Default Loose side marker - please help
Hi guys,
I decided last week I was tired of the clear side markers and wanted to put the orange ones back on. Went to do so last night. Worked fine on the passenger side, but not so on the driver side. The driver side marker is loose and just doesn't fit right. I bent the clip several times but no luck.
Should the clip be bent towards the body of the side marker or away from it?
If this doesn't work, perhaps just purchase a new set?
Thanks in advance!
Old 11-28-2010, 01:41 PM
996toomey
996toomey's Avatar
Once those clips are not tight very difficult to bend and make tight again. I had a loose one on a previous car and just replaced it with new.
Old 11-28-2010, 01:59 PM
LlBr
LlBr's Avatar
You want to add bending forces to reshape the tab or "clip" precisely - like in a surgical procedure. Two pairs of carefully positioned needle nose pliers would be used to accurately and carefully bend the tab to the proper position. Finger bending probably isn't good enough.
You can pull the spring steel clip from the plastic channel to work on it for better plier-bending access. Then shove it back in.
Here's what an undistorted 997 side marker tab looks like.
Old 11-28-2010, 02:29 PM
403portside
LIBr, thank you. This is helpful. I think I may have been bending it away from the body and this picture looks like it needs to be bent towards the body. Thanks again!
Old 11-28-2010, 02:31 PM
LlBr
LlBr's Avatar
I hope it works out for ya. Glad to help. It makes my day a little brighter.
Old 11-28-2010, 10:53 PM
Alan C.
Alan C.'s Avatar
I did the same thing as posted in #3 above and it worked fine.
Old 11-28-2010, 10:59 PM
Mspeedster
Mspeedster's Avatar
LlBr - what's up with your thumb? Looks like you've got a chunk of skin covering your finger nail.
Old 11-29-2010, 12:11 AM
LlBr
LlBr's Avatar
Heehee. Yeah looks gross. It's a found pic, I eliminated extra details for OP which were confusing. Here they are, with full thumbnail. :
Old 11-29-2010, 12:53 AM
403portside
It worked! Thanks!
Old 11-29-2010, 11:59 AM
LlBr
LlBr's Avatar
It worked! Thanks!
Excellent! Best part: no trip to dealer.
Old 11-29-2010, 12:47 PM
tkids
tkids's Avatar
Yeah, I was going to ask why MY Thumb looked all messed up?!
That pic is from a DIY posted on how to remove side markers.
Old 11-29-2010, 01:22 PM
LlBr
LlBr's Avatar
That's great - we helped the OP!
Old 04-04-2016, 11:20 AM
DGT3
2nd Gear
DGT3's Avatar
This worked perfectly! Thanks!
Quick Reply: Loose side marker - please help
