Worst coil pack ever?
Old 12-23-2010, 12:21 AM
cbzzoom
Registered User
cbzzoom's Avatar
Default Worst coil pack ever?
This just came out of my car :
Errm.. ain't there sposed to be some plastic 'round that thar metal?
Old 12-23-2010, 12:30 AM
Edgy01
Poseur
Edgy01's Avatar
Pacific Northwest--that says a lot. Get any RAIN up there?
Old 12-23-2010, 12:37 AM
jakes dad
jakes dad's Avatar
what the hell am I looking at??????????
Old 12-23-2010, 12:48 AM
Clifton
Clifton's Avatar
It is one of the car's six individual ignition coil packs. One end sits on the spark plug and the other end gets plugged into the cars DME.
Old 12-23-2010, 05:27 AM
JFScheck
JFScheck's Avatar
That there be some corrosion....
Old 12-23-2010, 09:13 AM
jumper5836
jumper5836's Avatar
How old is your car? Mine looked like that after 6 years of winter driving.
Old 12-23-2010, 12:06 PM
mcdonagh
mcdonagh's Avatar
I had to have all 6 replaced on my 2003 at 55k
Old 12-23-2010, 02:07 PM
cbzzoom
Registered User
cbzzoom's Avatar
2006 car, 42k miles
The car started misfiring a few days ago. I was expecting to find a coil pack cracked, because heard that happens - the plastic cracks from the heat and water gets inside.
Instead I found the plastic completely gone! And the metal plates inside rusty and warped. It amazes me that they kept working as long as they did.
This is roughly what they should look like :
Old 12-23-2010, 03:10 PM
Edgy01
Poseur
Edgy01's Avatar
The environment takes a greater toll than the mileage.
Old 12-23-2010, 09:16 PM
MichaelL
MichaelL's Avatar
I had all the coil packs replaced at 39K miles. A misfire & CEL. Three came up bad, so I had all replaced. My mechanic said that they all looked pretty bad. The coil packs are known to deteriorate from road spray and on cars that are not garaged. It has been reported that, once a single unit goes down, the rest will soon follow.
Old 12-23-2010, 09:53 PM
jakes dad
jakes dad's Avatar
What kind of money for the total replacement???? Just curious..
Old 12-23-2010, 10:13 PM
mobonic
mobonic's Avatar
Yes, Never just replace one. REPLACE ALL.
Also while you are there replace the spark plugs too.
I have a 2006 with 25k and I have replaced my sparks 2 times and the coil packs once after a missfire issue.
Also do not overtighten or you will crack the plastic and have to start all over again.
Old 12-24-2010, 12:22 AM
cbzzoom
Registered User
cbzzoom's Avatar
I paid $800 for 6 coils + 6 plugs parts and labor. The shop's parts were a bit overpriced, you could get 6 plugs+coils around $300 total online and save some.
Old 12-24-2010, 12:41 AM
Mike J
Mike J's Avatar
That is interesting. You think it was manufactured that way (no plastic), or is there plastic somewhere on your engine?
Old 12-24-2010, 02:59 AM
cbzzoom
Registered User
cbzzoom's Avatar
I assume some chunks of plastic are out on the road somewhere. These things are right at the bottom of the engine and totally exposed to the elements and the road. Most normal front-engine cars have these things on top of the engine, not the bottom, which protects them a bit.
Quick Reply: Worst coil pack ever?
