Remote stopped working...
Old 06-27-2011, 12:57 PM
lexart
lexart's Avatar
Originally Posted by jhbrennan
Replace your remote battery.
If it was only that simple . . .
Replacing the battery has no affect on this problem.
Old 06-27-2011, 02:38 PM
jhbrennan
jhbrennan's Avatar
No affect on your problem. Mine stopped and I replaced the battery and all worked again. Sounds like yours has lost sync.
Old 06-27-2011, 07:26 PM
DHC
DHC's Avatar
I had the same issue and also tried every iteration possible to get my keys to re-sync. The manual is not very helpful, but I finally stumbled on this approach, which worked great for me:
Lock the doors from the outside by using the key in the door lock.
Unlock the drivers side door using the key in the door lock.
Within about 10 seconds or so, open the door and insert the key into the ignition. DON'T START THE CAR!!
With the key still in the ignition, push the unlock button on the key.
Voila, you should be good to go.
The following 5 users liked this post by DHC:
bvshare (09-01-2022), gbworks (08-20-2021), IrishLegend (08-21-2020), nakism (12-10-2020), user 8298308 (02-08-2022)
Old 06-28-2011, 12:08 AM
sclemmons
sclemmons's Avatar
I just started having this issue within the last week and your fix solved my problem just now!
Now that is has happened to me, it is amazing how prevalent this problem is. Thanks for the easy solution.
Old 06-28-2011, 12:33 AM
Brad J.
Brad J.'s Avatar
Thanks DHC! I had replaced the battery, but hadn't been able to "sync". The first time I tried your method, it didn't work. The second, I set off the alarm, but when I put the key in the ignition (not starting the car) and pushed the lock/unlock button on the key it worked. My Key 1 is now working like it had before!!
Old 06-29-2011, 09:19 PM
lexart
lexart's Avatar
As you, I've tried every permutation of published steps to re-sync one of my keys. Nothing worked until I tried your procedure.
Bingo, it worked on the first try!!!
I think the main step is to push key unlock button while the key is still in the ignition . . .
Thank you for documenting this procedure for us!
Old 07-01-2013, 09:50 AM
sumpterc85
sumpterc85's Avatar
Default Porsche Cayenne 05
I've have been having this problem as well. Just brought a new battery and it has not worked. I am using the manual key lock process now...but in fear of the alarm sounding if I am not not quick enough with locking the door. I will try your process on the way home from work today...from the looks of everyone else's post, there could be some promise here! thanks in advance!
Old 07-01-2013, 11:40 AM
USMC_DS1
USMC_DS1's Avatar
Tag... I'm sure this will affect me at some point down the road. Thanks for the post and kudos to DHC for the solution. BTW, where did you come across this procedure. I'm surprised it did not include a dead chicken and a shrunken head. LOL
Sadeeq (12-23-2022)
Old 09-06-2013, 07:05 PM
Iceyankee-Tsi
Cruisin'
Iceyankee-Tsi's Avatar
DHC:
Thank you so much for this information! I tried everything too and no success. The worst part is that I bought this car second hand and only have one key! However, your approach worked flawlessly.
Very much appreciated!!!
Old 10-06-2013, 03:30 PM
Mathelo
5th Gear
Mathelo's Avatar
Wow! This list and Google are fabulous! Key stopped working a couple a days ago and this fixed it!!!
Old 10-17-2013, 08:52 AM
Charolastra
Charolastra's Avatar
....add another SUPREMELY HAPPY 997 owner to the success list! Thanks DHC!
Old 10-17-2013, 01:56 PM
fastm3
fastm3's Avatar
Shouldn't we have a sticky for these things??
Old 10-17-2013, 03:22 PM
jhbrennan
jhbrennan's Avatar
There is - see the third thread down from the top on the 997 Forum - https://rennlist.com/forums/showthre...ferrerid=39840
Lots of good info here - thanks to our resident "librarian" USMC_DS1 for maintaining it.
Old 10-18-2013, 08:39 PM
Edgy01
Poseur
Edgy01's Avatar
This is a sticky for you to follow:
https://rennlist.com/forums/997-foru...-w-photos.html
Old 11-15-2013, 06:20 PM
david
david's Avatar
DHC, many thanks for posting the solution and for the reminder about hibernation!
I hadn't driven the 997 in ~11 days and was only able to open the door this AM using the key. I thought at first she didn't like me any longer but she turned right over after the long slumber and immediately reminded me how awesome she is; that stupid smile has been on my face all day...what an spectacular machine!!!
I guess that I best not neglect her for so long next time, don't ya think?!?!?!
Thanks again and make it a fine weekend!
ttdan (06-04-2022)
Quick Reply: Remote stopped working...
