Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 03-10-2013, 08:57 AM   #16
zer026T
User
zer026T's Avatar
Quote:
Originally Posted by jhbrennan View Post
Key being stuck in the ignition is what happens when the battery is dead.
Ah, I missed that
To remove this ad, register today or login if you already are registered!
zer026T is offline   Reply With Quote
Old 03-10-2013, 11:24 AM   #17
911Steve
911Steve's Avatar
Quote:
Originally Posted by Edgy01 View Post
Every 997 owner should do this for themselves, but hopefully, not when they are forced to do it. A friend of mine left her key in the ignition of her late model Boxster--and it did what Porsche says it will do--it depleted the battery.
I simply brought along my car/battery charger, hooked up the negative to the door latch, and the positive side to the red terminal inside the fuse box. Plugged that into the 120V wall socket and then simply actuated the front trunk release (electronic). After that, I gained access to the car's battery and charged it up for awhile. Done.
That red terminal isn't that hard to grab with your fingers.
Dan,
Did you use the porsche battery trickle charger using the + and - leads? If so, could this same process be done through the cigarette lighter?
911Steve is offline   Reply With Quote
Old 03-10-2013, 11:46 AM   #18
jhbrennan
Quote:
Originally Posted by 911Steve View Post
Dan,
Porsche battery maintainer through the cigarette lighter doesn't work. Best to use the fuse box plug and an extra battery if available. If not then jumper cables. Don't jump the car to start, just to get enough juice to open the hood and recharge or replace battery.
jhbrennan is offline   Reply With Quote
Old 03-10-2013, 01:15 PM   #19
Techbod
User
I had a balky PCM that kept cycling off/on/restart/fail while driving. Parked the car in my garage, with nose tucked in under overhanging storage bin. Overnight, battery was depleted. Couldn't activate trunk release, nor open trunk far enough to access battery for jump even if it DID open.
Thanks to PDK, I couldn't simlly throw it in neutral and roll it back a few feet to access battery for jump.
So, before following fuse box jump instructions from manual, I had to phone roadside assist to talk me through manual override of PDK to move gear selector from P to N.
For future reference, it's done via a small hole in the storage tray in front of the shifter. Peel up the rubber grip tray insert. Insert a small flathead screwdriver and press downward on a hidden lever, then slide gear selector to N.
From there - simple rollback, fuse box jump, open trunk, battery jump start, and drive immediately to BH Porsche Service where faulty PCM diagnosis resulted in a total replacement of the system. Problem solved!
Techbod is offline   Reply With Quote
Old 03-10-2013, 04:57 PM   #20
911Steve
911Steve's Avatar
Understandable it wouldn't. Work right away, but lets say I left overnight to charge up batery, I should then theoretically have enough juice to open hood right?
Old 03-10-2013, 06:00 PM   #21
jhbrennan
While you had the manual out you could have found this and saved a call:
PDK selector lever emergency release
In the event of an electronics failure, the selector lever must be released for towing.
1. Lift up the rubber mat in the oddments tray.
2. Insert a screwdriver in the opening and press down until you feel it reach the limit position. The selector lever can now be moved to position N.
Paid Advertisement
Tags
911, 987, 997, battery, cayenne, cigarette, dead, electric, front, gt3, hood, latch, lid, lighter, open, porsche, trunk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
