Tell Me Something I don't know about the 997
Old 04-08-2021, 03:58 PM
  #211
Carreralicious
Carreralicious's Avatar
Originally Posted by David Berry
where did you get that? I want one just like it, matches the other pedals.
Suncoast Porsche parts sells it online. To remove the old one just use a trim tool and wedge it under the pedal and then lever it upwards as you use your right hand to hold the side and pull up. It will pop out. Then slide the new one downwards and it will pop right in.
Old 04-08-2021, 04:44 PM
  #212
crazy997
crazy997's Avatar
Not sure I saw this one in the thread yet:
Lock the door TWICE rapidly if you want to keep the doors locked while a passenger remains in the car. Otherwise, the alarm will go off after a brief period of time if you only lock the doors ONCE. It's in the manual.
Old 04-08-2021, 10:29 PM
  #213
rileyracing1
rileyracing1's Avatar
[QUOTE=kkswow12;17351935]
Originally Posted by Edgy01
When just moving the car around a little you can avoid putting on your seat belt and getting the annoying gong by keeping the speed below 15 mph indicated. Once you hit 15 the gong will continue to sound.[/QUO!!!!!!
Or just get any decent Porsche OTC program scanner tool and turn the damn thing off permanently as I did ...Beautiful xoxox
Old 04-14-2021, 01:04 PM
  #214
j_leder
j_leder's Avatar
Supreme trivia of the least known kind: This only applies to those who have the Sport Chrono Option.
With that option you have the ability to go into the PCM and either select "daylight running lights" or not. BUT, you only get that option when the VEHICLE IS STANDING STILL. It is disabled while in motion. (Must be a German safety thing). None of this applies if you lack the wart, because you have to go to the dealer to change that stuff for you. That function is also 'keyed' to whichever key you have in the vehicle at the time.
Can you help me? I have the sport chrono(the wart). the only option it gives me is start timing. I have a 2008 Carrera S. Is it unavailable in this model year. Can you give me some more information as to activate the daytime running lights?
Only stop watch shows
Much appreciated.
Jeff
Old 04-14-2021, 04:24 PM
  #215
Jance
Jance's Avatar
If you have Sport Chrono, you have two speed limit notifications. One set on the dash and one set on the PCM. I set my PCM to 75mph to indicate to passengers, and I set the dash speed limit notification to 100mph.
Old 04-14-2021, 06:11 PM
  #216
Carreralicious
I haven’t done this adjustment, as I think turning on this feature makes your main headlights turn on all the time when you drive but I think Edgy is saying you make the adjustment in the PCM (eg. nav/radio unit settings), and not the indicator stalk.
Much appreciated.
Jeff
Old 04-14-2021, 10:04 PM
  #217
z3mcoupe
z3mcoupe's Avatar
Passenger side window is auto-up only after it's reached the half-way point on the coupe. On the cabs, the auto-up on the passenger side feature works with the window fully closed.
Old 04-16-2021, 06:58 PM
  #218
Optionman1
Optionman1's Avatar
Received 2,145 Likes on 1,013 Posts
The headlight washer system automatically sprays once for every ten times the front windshield washer system is operated
Quick Reply: Tell Me Something I don't know about the 997
