What did you do to your 997 today?
#5866
Stripped, clay bared, then used chemical guys blacklight x 2, jetseal x 2, then V7. Interior was cleaned, then used Formula 303 for rubber, gummiphlege for seals.
Front end needs a respray but will wait until after an upcoming long drive. Also rear fender, side mirrors, door pulls need removal of film and reapplication.
Not bad for car with 116k miles.
#5867
Updated the mounting hardware on my 991 side skirt project (all black), and went for an evening drive:
Updated DIY thread:
https://rennlist.com/forums/997-foru...diy-below.html
Updated DIY thread:
#5869
Installed H&R springs on my 997.1 C2S. Accidentally ripped the rear PASM wire right at the base of the threaded shock shaft. Ordered a used rear PASM shock on eBay for $200 shipped.
Note to self/others: don't use an electric impact with the special cut-out socket to fully remove the strut nut. The wire just ends up wrapping around the socket. A manual ratchet/socket did the trick just fine on the other side.
Other than that, suspension install is a breeze.
#5872
Same - I did black/tan checkered in my natural brown full leather with a black Sport Design (GTS) steering wheel. I love it.
#5874
Here....
https://www.cocomats.com/
Note that there are lots of cheap asian imitation versions on Ebay and other sites. These are made in South Carolina.
#5875
Really badged my 997.2 carrera , removed carrera and installed 911, some ghosting of carrera but easily removed it with "Rutland White Off" it's a glass cleaner for fireplaces .worked great! No swirling or scratching .
#5877
TODAY WAS A GOOD DAY.....
Not a CEL code in sight,
And everything was alright.....
-Ice Cube
-Ice Cube
#5878
Covered the last bright metal on the car with this clever plug from Bumper Plugs (no affiliation).
#5880
