Oil Wrench size 997.1
I went into some forums and read up on the size for a oil wrench for 06 C4S and i got 74mm 15 flute well made my way to local auto tool bought one by the way made in the good USA got home and does not fit , im i missing something here can anyone help me out also been told that mercedes dealers sell the wrench and it fits Porsche , thanks
You probably got the #8 one? You need the #7 one which Canadian Tire or Parts Source don't seem to carry.
I think it's actully 14 flats you need, I ended up buying the fabric strap type wrench at Canadian Tire, only $7.50, you will need a 1/2" drive wrench to use it, it works fairly well as I did my first oil change today.
I cleaned the exterior housing surface very well then hand tightened the housing while wearing those blue Nitrite gloves for grip, the housing is actually quite solid even though it is not metal so I was able to snug it up pretty good.
At some point I hope to find the right #7 filter wrench so I can lossen the filter and torque it tight properly, but the strap style wrench and a good/solid hand tightening will do for now.
As well, I've been told a number of German cars use the same size filter, which makes me wonder why the wrench isn't more available, at least here in Canada anyway.
