car in the garage for 3 weeks: recommendation
hi,
I will be gone for the next 3 weeks. Car will sit in the condominium garage. Any suggestions? Is this long enough time to worry?
Thanks,
Fernando
Thanks,
Fernando
how long do you think cars sit on lots? not sure how often they start them up, doubt they're on a trickle
Miserable Old Bastard
It would be best to have a trickle charger, but for 3 weeks you'll probably be OK. You will need to open the door lock manually with the key when you get back.
I returned to an almost dead battery from a 3-week trip a few years ago. Had zero issues starting the car prior to the trip but maybe that battery wasn't a good proxy being almost 3 years old at the time. These cars do use battery power when parked though whether you have something plugged in or not. After that incident I disconnect the battery when traveling for more than two weeks. If you go that route, DON'T close/latch the front hood since none of the release buttons work without battery power. If you feel that you have to close the hood being in a condo garage you'll need jumper cables and another battery to get the front hood open. Go to your fuse panel and look for a red bar in the upper right hand corner. That pulls out and you attach the + jumper cable to it.
+1 on sandwedge, or as suggested above, get a trickle charger (battery tender) if you have electrical access in your condo garage and plug it in before you leave. These cars love to eat batteries.
If you have a Trickle Charger throw it out. They are out dated. A battery tender monitors the battery voltage and shuts effectively off when the battery is fully charged. A trickle charger puts out about 2 amps forever. If left on for an extended period it will boil away your electrolyte.
