Heated Seats not working
Old 01-26-2012, 07:03 PM
Minok
Minok's Avatar
The temperature put out would likely be determined by the current going through the system, assuming there is only one heating element circuit in the seats (as opposed two in parallel where they switch on one for warm, both for hot). So increasing the voltage applied over the fixed heating element resistance increases the current and increases the heat.
So anything that restricts the current - a bad connection, the switch/regulator to the heating element, etc. could cause some but not enough current to flow, thus the thing not to heat up properly. It would be informative (and less subjective vs hot enough for me vs you) if we could read the current levels running into the seats when the heating is on on low and high.
Old 01-08-2014, 03:44 PM
towney
towney's Avatar
I'm having an issue with the drivers side heated seat. When I push the button the red light comes on and then goes off, light does not stay on. Passenger side works.
Any thoughts on a solution/fix?
Old 01-08-2014, 10:54 PM
ddrxdd
ddrxdd's Avatar
I have the Adaptive Sport Seats w/ lumbar & they get HOT on high.
Old 01-09-2014, 03:31 PM
Minok
Minok's Avatar
I'd guess some sort of monitoring/safety function is turning the seats off. Not sure why - maybe the seat is unplugged from the controller or there is a detected fault.
Old 02-28-2016, 10:10 PM
911searcher
911searcher's Avatar
Probably a short.
Quick Reply: Heated Seats not working
