997 preventative maintenance: water pump replacement? Help Macster!
#76
Poseur
You may notice that the majority of 997 water pump issues are with the 3.8 engines--not the 3.6
My 3.8 WP died fairly early, detected by dribbling on the garage floor. Warranty replacement (because I actually drive my car).
Unless you know something is amiss with your 997 3.6 I wouldn't replace it as a part of a Preventative Maintenance plan.
#80
I just replaced my water pump Saturday. 2005 997. It is the second water pump. First one at 27000 miles, second one at 48000. Used only the genuine Porsche water pump. Hope it last more that 15000 miles.
#81
My pump lasted 12 years 65Kmiles - first noticed coolant level drop in expansion tank - then noticed small coolant leak undercar - could not detect any play on the bearing - but I guess enough was there to let water out under pressure. Replaced with Pierburg pump from Pelican (on 3.6 996). My buddies '07 boxster broke WP shaft at 90K. 3 year preventative (given cost) may be a little **** - but if you got to 10 years/60K - seems like it might be warranted if you are going to keep your car another 60K/5 years ...
Also agree with going with original factory t'stat .....
#82
2007 3.6 60k miles.
Replaced WP, T-STAT, and S-BELT about 3 weeks ago as a preventive maintenance with all genuine P parts. Had the parts sitting around for about 2 years then decided to just get it done... The OEM WP looks fine with just some minor scuffs on the blades and bearings were fine. No leaks prior to maintenance. Definitely could have gone without the change for a while longer. But did noticed bearings starting to go on the pulley sitting off of the crankshaft.
#83
This should get you started:
https://rennlist.com/forums/996-foru...ps-attack.html
I purchased the 101 projects for your 911 (996-997.1) and in the book the engine is not even lifted up, and there is no mention of procedure differences between 997.1 and 996.
Book also states that the 210 deg full open thermostat should be changed out with a 180 degree fully open type.
#84
Have a look at this site and read buyers guide #5 in particular.
http://www.hartech.org/buyers.html
It is a long read, but ... it also deals with 160*F T-stat and why it makes sense to have it installed in certain situations.
Far more info than LN Eng. web site and well documented. Engine thrust sides, changes to head gasket, overall condition of coolant, etc, etc.
I just replaced my water pump, installed 160*F T-stat and added 3rd rad.
And going to replace coolant with fresh mix. Mind you after almost 7 years of service coolant looked not too bad at all.
Cheers,
=L=
Cheers,
=L=
There is a lot of discussion about a general loss of coolant flow rates in the all important cylinder areas, and the fear of scoring, piston coating scrape off, and cracking of the cylinders. Not so much focus that the greatly increased water flow into the heads brought down the head/combustion chamber temperatures. Some of this to reduce pre-ignition, allowing higher compression and more output. A cooler head will also allow the oil in the head to be much cooler on return to the oil sump. Also, cooler heads will attract heat from the cylinders they are bolted to, especially the upper areas where the flames are.
There seems to be a determination (from Porsche) that the oil temperatures needed to be reduced. The 3.8 even has an oil cooler, and all the 997.1 models holds 8 gallons of coolant, while the 3.6 holds 5.5 gallons, which itself is a lot of coolant comparatively speaking. That, coupled with 8.5 quarts of oil for 325 hp seems conservative. Now, a poor design decision would be apparent if the water took a course through the engine where it's entry and exit temperatures where closer to equal, meaning the water did not absorb unwanted heat from the engine. But I didn't see where the report analyzed this from that perspective.
Are they recommending a different head gasket design between banks on the later 3.6 and 3.8 engines, or just a lower temp thermostat ?
#85
I live in Nevada, and the oil temps have usually been < 200 F, when the car was fully warmed up. In the last few days, with the heat wave, day ambient temps in the 110 F range, I am noticing that the oil temp guage is showing about 210 F on a routine basis. car is otherwise working fine.
Is this increase likely due to the increased ambient temp ?...or is this a Water Pump issue. I have a 2009 C4S with 27000 miles.
#86
An increase in the ambient air temperature will bring an increase in oil temperatures. I believe getting the oil above the water boiling point will help purify the oil.
#87
#88
So I've read every post here with keen interest, I wanted to know as much as possible before jumping in, I just finished a 4+ hour job with assistance changing my water pump, thermostat and housing and 2 idler pulleys and the tensioner pulley (which was faulty so had to use the old one).
This is by no means an easy job, due to the cramped space you have to work with, I reckon it could have been done in less than 3 hours, but the old water pump was completely smashed so the impeller hooked the pump from sliding out, and so did the pulley we had to smash the impeller to get it out to free up the pump
Chucked in a gallon of distilled water and a gallon of coolant and we're on the go again!
Total spend $427 on parts.
#89
Congrats on the DIY! Was that the original WP? How many miles on the car and more importantly the WP?
FWIW, I tackled this same DIY during the Thanksgiving holiday break. Car had 75K+ miles and 8 yrs on the clock. Did a pre-emptive WP and low temp t-stat R&R.
#90
Yes that's the original WP, this car has a strange history, very low mileage at less than 9k because it's a salvage and has spent most of the last 9 years parked and abused, this is the first time the WP is being changed since the car was made.
