Best product for rubber?
Old 04-13-2012, 12:04 PM
dak911
dak911's Avatar
Default Best product for rubber?
What is the best product to use to keep RUBBER flexible (not vinyl, actual rubber shift boot)
Old 04-13-2012, 12:14 PM
PHX 911
Official Rennlist Snake Slayer
PHX 911's Avatar
Maybe 303?
Old 04-13-2012, 01:30 PM
ADias
ADias's Avatar
303 Aerospace Protectant available from Amazon -
Amazon Amazon
I buy it by the gallon. Applied on rubber weather seals and plastic vinyl protects its original back look and suppleness,
Old 04-13-2012, 03:27 PM
NA011
NA011's Avatar
Location: Treasure Island, Florida - Home of the Wide Beach
+1 on the 303 Aerospace Protectant. It provides great sun protection. After using the 303 wait 2-3 weeks and top it off with Gummi-Pflege
http://www.z3bimmer.com/OffTopic/E24Bimmer/Gummi/
Old 04-13-2012, 07:08 PM
ddd269
ddd269's Avatar
Great info!
Thanks!
Old 04-13-2012, 08:31 PM
USMC_DS1
USMC_DS1's Avatar
yep, 303...
Old 04-13-2012, 08:46 PM
Spokane5150
Spokane5150's Avatar
I've always used Spray Silicone to lube all the rubber bits inside and outside my vehicles. It's what my father did and always seem to work on the door seals and all the stuff under the hood. It makes everything look new and brings back the luster of the rubber parts. I think it works good. I even spray it on my forks and shock of my dirt bike and have never had a seal failure. Maybe the old man knew what he was doing. I really never gave it much thought.
What do you guys think about using Silicone Spray?
Found this on line.
DESCRIPTION:
Silicone spray retards corrosion. Makes cleaning easier and quicker. Dries fast with no greasy or oily film. It saves valuable time while it protects and preserves equipment. Colorless, non-staining, waxless and heatstable-unaffected by temperatures ranging from -40°C to 204°C. It has unusually low surface tension properties.
USES:
Furniture/Auto Trim/Upholstery: Speeds cutting and sewing while eliminating material drag.
It stops bunching and binding and facilitates fabric flow. Printers: Prevents rust on paper cutters,
drills, dies, saws, etc. Prevents the adhesion of glue to equipment. Hardware/Industrial Maintenance: Eliminates sticking problems in plastic and rubber molding. Helps fight
rust on tools and equipment. Prevents adhesion of sticky materials to equipment.
Old 04-13-2012, 08:52 PM
Spokane5150
Wow! 303 may be the best way to go.
Old 04-13-2012, 08:54 PM
USMC_DS1
USMC_DS1's Avatar
Silicone spray was my go to as well previously but discovered 303 last year on this forum. I prefer 303 because it not "too" shiny. Looks more natural to me and I believe the protective quality is better - good enough for marine/boat applications.
Old 04-13-2012, 10:23 PM
NA011
NA011's Avatar
You can also use the 303 on most leather:
http://www.303products.com/shop303/i...ve-leather.cfm
Old 04-13-2012, 10:29 PM
fc2s
fc2s's Avatar
Does anyone know where we can we buy 303 in canada?
Old 04-13-2012, 11:02 PM
ADias
ADias's Avatar
Can't you get it through Amazon?
Old 04-13-2012, 11:31 PM
acao
acao's Avatar
I'm gonna be rebellious and nominate Gummi Pflege. Your BMW dealer has it.
Old 04-13-2012, 11:34 PM
fskof
fskof's Avatar
Try a boating goods store.
Old 04-14-2012, 09:11 AM
Dukec4s
Dukec4s's Avatar
303 has my vote. I use it on my tires too....gives them a natural " new rubber " look....
Quick Reply: Best product for rubber?
