997 DIY and Tech Index
Old 04-27-2015, 04:34 PM
  #46
socheydna
2nd Gear
socheydna's Avatar
How to wire the 997.2 LED front conversion box with 991 fod lights and side markers?
Old 05-05-2015, 12:34 PM
  #47
ltcjmramos
ltcjmramos's Avatar
Centerlock wheel subject matter found over on 6speed, but links are here:
http://www.6speedonline.com/forums/9...ips-tools.html
GTS owners and other interested folks:
Here are some compiled threads and info:
http://forums.rennlist.com/rennforum...s-learned.html
http://forums.rennlist.com/rennforum...-diy-guys.html
http://forums.rennlist.com/rennforum...-2010-gt3.html
http://www.suncoastparts.com/category/gt2rswheac.html
The attached scan can be rotated using rotate under view tab
Maybe we could start a repository here in GTS/997.2 land
Old 05-11-2015, 08:20 PM
  #48
jhbrennan
jhbrennan's Avatar
You didn't copy the entire post - no pdf scan attached??
Old 05-11-2015, 08:26 PM
  #49
ltcjmramos
ltcjmramos's Avatar
Does this work? Trying from my iPad. If not, I'll try from my desktop later.
http://www.6speedonline.com/forums/a...0&d=1298219279
Old 08-03-2015, 12:04 AM
  #50
sttmad
sttmad's Avatar
Does the factory alarm on a 2008 997 supposed to chirp when it's locked?
Old 08-03-2015, 01:38 PM
  #51
nwGTS
nwGTS's Avatar
No, just the lights flash as per the owner's manual.
This thread has more info for you:
https://rennlist.com/forums/997-foru...he-remote.html
Old 09-21-2015, 02:19 PM
  #52
wwilliams88
wwilliams88's Avatar
I wrote a procedure for removing and repairing issues with the windshield washer tank, 997.2 style. The PDF can be found in post 23 here:
https://rennlist.com/forums/997-foru...t-working.html
Old 09-29-2015, 05:53 AM
  #53
sdpnoy
Cruisin'
sdpnoy's Avatar
Thanks for this thread. This definitely helped with my decision to get a Porsche.
Old 10-29-2015, 09:02 PM
  #54
StormRune
StormRune's Avatar
If you decide to add a wing and deck lid assembly from a Turbo to any Carrera model, here is a DIY for that: https://rennlist.com/forums/997-foru...a-carrera.html
Old 11-04-2015, 11:50 AM
  #55
yvesvidal
yvesvidal's Avatar
Not sure if you have any interest in this one, but to change your clutch and flywheel, read on: https://rennlist.com/forums/997-foru...1-c4s-c2s.html
Yves
Old 12-24-2015, 02:18 PM
  #56
syzygy333
syzygy333's Avatar
Just a Thank You USMC (Ooo-rah) for compiling these DIY's.
I have had my car 2 whole weeks and this list has been a real
benefit
Old 12-25-2015, 09:36 AM
  #57
USMC_DS1
USMC_DS1's Avatar
Merry Christmas syzygy and GL with the DIY's... that's always been part of my own p-car ownership fun. I have a lot of projects to tackle next week as well when I get back home.
Old 12-25-2015, 11:14 AM
  #58
RichFL
RichFL's Avatar
Merry Christmas to all and especially USMC for organizing the DIY's.
Old 02-02-2016, 12:16 PM
  #59
swc99
swc99's Avatar
Default Disable TPMS DIY
USMC, Thanks again for putting this together. Excellent resource!!
I didn't see the DIY for disabling the TPMS included:
https://rennlist.com/forums/997-gt2-...ric-6-pro.html
In my mind, I think this is a great alternative to the hassle and expense of purchasing and installing new sensors when the time comes to replace. I would much rather put that time and money towards a durametric tool that I could also use for other things, and just keep track of tire pressures the old fashioned way.
Old 08-09-2016, 10:19 PM
  #60
EMC2
EMC2's Avatar
Adding a few more from my past threads:
Porsche 911 (997.2 & 997.1)
997.2 Center (3rd) Radiator Kit DIY https://rennlist.com/forums/997-foru...don-t-fit.html
997.2 Function First Transmission Mount DIY https://rennlist.com/forums/997-foru...r-997-2-a.html
997.2 Oxygen (O2) Sensor Replacement DIY https://rennlist.com/forums/997-foru...placement.html
997.2 Brake Caliper Upgrade and Refinishing DIY https://rennlist.com/forums/997-foru...2-c2-base.html
997.2 Laminex Headlight Restoration and Laminex Tint Install DIY https://rennlist.com/forums/997-foru...ion-diy-2.html
997.2 Techart Spring, Bilstein B6, GT3 Swaybars & Tarret DropLinks Install and review https://rennlist.com/forums/997-foru...r-install.html
997.2 991 Style Projector LED Headlights - Product Tear Down, DIY and Review https://rennlist.com/forums/997-foru...pic-heavy.html
997.2 OEM Clear Stone Guard Installation DIY - https://rennlist.com/forums/997-foru...me-stress.html
997.2 Vacuum Level at Oil Filler Neck (let's build a data resource) - https://rennlist.com/forums/997-foru...-resource.html
997.2 - Side Decals Installed - Matt Black on Black 997.2 - https://rennlist.com/forums/997-foru...k-997-2-a.html
997.2 3.6l AOS (Air Oil / Oil Mist Separator) DIY - https://rennlist.com/forums/997-foru...l#post13848924
997.2 - 991 Side Skirts installed - DIY - https://rennlist.com/forums/997-foru...l#post14229861
997.2 - 991 Custom Rear Splitters / Skirts installed - https://rennlist.com/forums/997-foru...97-2-done.html
997.2 - 991 Sports Lip / Spoiler Adapter Kit - https://rennlist.com/forums/997-foru...l#post15196257
997.1 - 991 Sports Lip / Spoiler Adapter Kit - https://rennlist.com/forums/997-foru...97-1-done.html
997.2 - Water Pump Replacement DIY - https://rennlist.com/forums/997-foru...ement-diy.html
997.2 - Center / Third Radiator Installation using less expensive 997.1 Kit - https://rennlist.com/forums/997-foru...don-t-fit.html
fluxdon (03-31-2024)
Quick Reply: 997 DIY and Tech Index
