View Poll Results: Have you had to change your TPMS batteries yet?
Yes
12.28%
No
68.42%
I don't have TPMS on my car
19.30%
Voters: 57. You may not vote on this poll
$1300 for TMPS battery change????
Old 09-07-2012, 10:20 PM
  #31
Mumbles
Mumbles's Avatar
Originally Posted by door2416
That works for your tire pressure but you can't check your oil level with your dash lit up with the warning message.
So porsche expects you to renew the batteries within say two weeks as you cannot check your oil level ? no way to get the warning off the screen ?
Is this the same in the DFI engines ? 997.2
Cheers
Old 09-08-2012, 02:43 AM
  #32
RennlistTomE
RennlistTomE's Avatar
$1300 for the TPMS transmitters?
Shall we assume that includes a set of new tires at no additional charge?
Old 09-08-2012, 04:22 AM
  #33
sandwedge
sandwedge's Avatar
Received 1,008 Likes on 716 Posts
Originally Posted by Ptech1
Was passing on the info as a Porsche tech. That data (along with every other aspect data wise) is accessible with our scan tools for diagnosis of TPM system.
Can you confirm that these sensors come with two different frequencies? I just mounted a new set of wheels that came with sensors that are only 1.5 years old and they won't talk to my car. I've been through the set-up drill ten times over and it's no use. It gets to the "learning" point and then it's over. My dealer says I got unlucky and got the wrong frequency for my car. Hard to believe knock off sensors from Tire Rack will be an easier transition than a set of 1.5 year old factory sensors that came off a .2 car just like mine.
Old 09-08-2012, 09:51 AM
  #34
door2416
door2416's Avatar
Hey Ptech1, Is there a way to turn off the learning message so I can check my oil level. I am running summer tires that do not have sensors.
Old 09-09-2012, 10:39 PM
  #35
ronmart
ronmart's Avatar
Originally Posted by paddyh
I ordered 4 replacement sensors from Tire Rack. Together with the Valve Kit and shipping, the total was ~$392. Installation at my local tire store was about $80.
I have a long relationship with the tire dealer, and watched from inside the shop as they put the Porsche up on manual jacks, and removed the wheels by hand etc. ymmv.
You are confusing the controller unit that we are talking about here with the valve kit that you have to replace whenever you remount the tires. The part for the sensor hasn't been available for less than $110 on any legit sources I've seen on the web. The valve kit can be found for as little as $30 each.
Old 09-10-2012, 09:59 AM
  #36
Quadcammer
Quadcammer's Avatar
Received 1,372 Likes on 794 Posts
Originally Posted by kosmo
Remember that the sensors are model specific. You cant buy generic. For example what works on a 2011 may not work on an 2009.
While you're right that what might work on a 2011 may not work on a 2009, they are usually not model specific, but rather frequency specific.
All you need to do is figure out which one your car has, and you can buy the generic ones from tirerack, ebay or whatever.
Old 09-10-2012, 10:31 PM
  #37
py0413
py0413's Avatar
$1300 for 4 TPMS sensors is just insane. Again there s the reason we call them stealerships.
Old 09-11-2012, 04:15 PM
  #38
Minok
Minok's Avatar
$1300 is the parts ($400+) plus the labor to unmounted the tires, replace the sensors, remount the tires, and then likely balance the tires.
That does seem high though for the labor side. Consider a quality tire shop that does lots of Porsche work to have new sensors installed. It helps to keep track of when they are due to be swapped so you can put new ones in when you do the tire change near that time.
Old 09-11-2012, 09:43 PM
  #39
Mumbles
Mumbles's Avatar
Balancing these wheels aint cheap.
Old 09-11-2012, 10:14 PM
  #40
mjsporsche
mjsporsche's Avatar
Yeah...about $100 give or take a few. I thinkthe cost of balancing is still reasonable. And we are not limited to dealerships to do that work.
Old 09-13-2012, 09:57 PM
  #41
Ptech1
Ptech1's Avatar
There are different frequencies, but they only differ from year to year over wide ranges (more like model to model). It's possible that the new sensors may need to be programmed to the car manually if they are not being picked up by the system almost immediately (would require the ID numbers on each sensor). Or you may have just gotten 1 or more bad sensors...
Old 09-13-2012, 10:36 PM
  #42
Ptech1
Ptech1's Avatar
Unless I'm missing something, you should be able to back out of the learning message when exiting the info screen as normal, at which point the warning "!" will stay lit.
Quick Reply: $1300 for TMPS battery change????
