clutch life , 997
Old 12-22-2012, 01:15 PM
Tcc1999
Tcc1999's Avatar
If you end up replacing the clutch, and since they have the transmission open, you may want to think about a new flywheel if you're looking for that type of performance mod.
Old 12-22-2012, 04:01 PM
Renzsport
Renzsport's Avatar
how cold is it in mtl these days? Hydraulic clutches get extremely lethargic and "sticky" at startup until warm when it's cold out (-10 colder) - which is what it almost sounds like you were describing... especially if you said it was fine afterwards
Old 12-22-2012, 04:03 PM
Renzsport
Renzsport's Avatar
my bmw's at >217000km on the original clutch. I imagine the porsche won't go that long, but no reason to not expect 100k
Old 12-22-2012, 05:26 PM
hazmanT4s
hazmanT4s's Avatar
Default v
My BMW did 190km on one clutch and I was also driving it like crazy all the time , but I'm first time Porsche owner since last April , I'm still fresh , I've been BMW all my life , just put winter tires on it , and cost an arm and leg and now clutch and the holidays all together , it's a good way to finish the year haha
Old 12-22-2012, 08:35 PM
MLindgren
MLindgren's Avatar
Mine did the same thing and it turned out the pressure plate failed. I recommend having the repair done at the dealer since they may have a shot at some sort of good will from Porsche. Pressure plates shouldn't fail.
Old 12-22-2012, 10:43 PM
jw1977
jw1977's Avatar
I did my C2s clutch at 37,000 miles. I don't race mine, or drive spiritedly quite frequently. I never do really hard launches, i do all of city driving.
Old 12-23-2012, 04:29 AM
Edgy01
Poseur
Edgy01's Avatar
Originally Posted by hazmanT4s
Hello I have targa 4s 2007 , I have 55300km on the clock , it's 6 speed how long the clutch will last , what the normal life for the clutch
Since you have about 35,000 miles on that car you shouldn't need a new clutch for another 70,000 miles---IF, you drive it without slipping the clutch.
These clutches should last 100,000 miles without replacement assuming you know how to drive a manual transmission car and don't get silly with it. The 997.1 cars had the self adjusting clutches on the S models only (which is yours) while the 997.1 non-S cars didn't have it. By the time the 997.2 cars arrived Porsche put in the self-adjusting clutches across the line--both normal and S models have them now.
The real issue at hand is how to drive a manual transmission car. Do not accelerate when the clutch pedal is not fully released. Just give it a little gas to get it going. For example, I often release the clutch when going from stop into first gear at about 5 mph. The secret is to never hit the accelerator hard for power when the pedal is not fully released. The characteristic clutch smell will tell you when you screw up. It takes some practice with the footwork to do this correctly.
Old 12-27-2012, 12:24 AM
blake
blake's Avatar
I just needed to replace my clutch at 42k. Cost: $2300. I looked into the DIY (Suncoast parts at under $700), but quite frankly don't have the time...
I'm a bit confused as I have owned and driven many manuals - and several from new to 100k - and have NEVER had to replace a clutch. I bought the "S" under CPO at 25k about two years ago, but the car had zero type III or above over-revs.
I must be doing something wrong.
-B
Old 12-27-2012, 08:52 PM
CORSASCHNELL
CORSASCHNELL's Avatar
I have seen clutches replaced on some cars at 22 K miles due to super aggressive driving or lack of proper skills, or both. So expected life is between 22-80K miles.
Old 12-28-2012, 11:30 AM
pv355
pv355's Avatar
I replaced my clutch at 50k miles. I bought the car with 30k. Judging from the avg speed from the DME of 30 mph, the previous owner had a similar driving mix as me, which is about 70/30 city/highway.
Old 01-05-2013, 11:41 AM
hazmanT4s
hazmanT4s's Avatar
Default doing the clutch today
Car on the jack suppose to be ready at the end of the day
Old 01-05-2013, 11:54 AM
Spokane5150
Spokane5150's Avatar
Do you rest your foot on the clutch pedal? I test drove a 911 a few years ago and the clutch was smoked. Apparently, the gent that owned it had a stroke and traded the car in for an automatic. The stroke had affected his left side so his right leg was weak. He apparently rested his foot on the clutch all the time.
I've notice while riding with people that they slowly disengage the clutch after the car is moving shifting through the gears.
-B
Old 01-05-2013, 12:16 PM
hazmanT4s
hazmanT4s's Avatar
Default clutch
So I found out that I'm not a bad driver , haha my slave cylinder fail pinned the fork and the damaged the pressure plate
Old 01-05-2013, 02:38 PM
hazmanT4s
hazmanT4s's Avatar
Default clutch kit
Bought a clutch kit complete original Sachs for 685& Canadian dollars plus the fork for 50$ and the slave for 150$ is that a fair price
Old 01-07-2013, 01:33 PM
sullivas
sullivas's Avatar
Any fluid leaks under the car? Just thinking maybe clutch slave is leaking or has air in line. Check master reservoir and make sure fluid is above clutch fluid entry hole.
Quick Reply: clutch life , 997
