crunchy water pump failure - DIY or Shop?
Old 09-09-2019, 04:34 AM
Dave R.
Dave R.'s Avatar
Turns out the crunchy noise was just from the water pump bearing, the impeller vanes looked just fine.
I had the car flat-bedded to the local Dealer which replaced the water pump and also replaced the two idler pulleys and the tension pulley which were badly worn and grooved - apparently because coolant from slight leaks before the water pump really let go allowed the serpentine belt to slip and wear the idlers.
In hindsight a warning sign that the water pump was starting to leak was several seconds of belt squeal on startup from coolant on the serpentine belt.
Labor was over $900 (back then). Will likely DIY the next one.
Old 09-09-2019, 11:22 AM
yelcab
yelcab's Avatar
it took 6 years to fix?
Old 09-09-2019, 12:13 PM
Dave R.
Dave R.'s Avatar
No, fixed back then. Just realized I’d not closed the loop.
Quick Reply: crunchy water pump failure - DIY or Shop?
