How to Override a Faulty Clutch Sensor
Old 04-27-2013, 11:46 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Default How to Override a Faulty Clutch Sensor
My clutch sensor has been acting up lately, so I contacted Porsche in Greensboro about scheduling an appointment to replace the clutch sensor and a couple of other minor warranty items.
The Service Manager told me that if I had another issue with the clutch sensor prior to getting it replaced, that I should continue to depress the clutch and continue to hold the key in the "start" position for about 30 seconds, then the car would start.
Is it turned out, two days after he told me this I did get the "Depress Clutch Pedal" message. I held the clutch and the key as instructed and the car did start, just as the SM said it would. Apparently, the sensor fault lasts for about 30 seconds, after which the "disabling function" is turned off.
I thought this might help some other Rennlisters in the future.
user 3470812 (01-05-2023)
Old 04-28-2013, 09:05 AM
gota911
gota911's Avatar
I guess everyone except me knew about the 30 second override.
Old 04-28-2013, 11:09 AM
Gripster
Gripster's Avatar
Why do you think that?
Old 04-28-2013, 11:57 AM
sbpsu354
sbpsu354's Avatar
Thanks Tim! Just had the clutch switch replaced on my 2010 C2S for the exact same reasons
Old 04-28-2013, 12:41 PM
gota911
gota911's Avatar
I was surprised that the thread had over 60 views but no comments, so I figured that the content was common kowledge to everyone except me.
Old 04-28-2013, 08:18 PM
Gripster
Gripster's Avatar
I made mental note of it but didn't have anything to add. It's one of those things that's only useful when you're having the same problem. The next person searching for faulty clutch sensor will surely happen upon this thread so thanks for posting!
Old 04-28-2013, 10:12 PM
Volnomad
Volnomad's Avatar
Thanks for the tip! My wife's Boxster just started having the same problem.
Old 04-28-2013, 10:31 PM
dbv1
dbv1's Avatar
I thought that clutch switch was cheap and easy to change. Friend of mine had the same problem.
Old 04-28-2013, 10:48 PM
Domer911
Domer911's Avatar
Sweet. Thanks, OP. Nice catch! I suspect that's gonna come in handy sooner rather than later.
Old 04-29-2013, 11:34 AM
gla
gla's Avatar
I did not know. I will remember. Thanks
Old 04-29-2013, 12:24 PM
ecostellodo
ecostellodo's Avatar
Thanks for the tip!
Old 04-29-2013, 02:33 PM
TxBob74
TxBob74's Avatar
It is easy. Per my service advisor, PCNA allows 0.1 hr (that would be six minutes) for the tech to take the car into the shop, change out the switch and return the car to the front.
Supposedly my car's VIN was not on the list for replacement, but after 4-5 incidents away from home, enough was enough. They did the change at no cost to me.
Old 04-29-2013, 02:44 PM
MJBird993
MJBird993's Avatar
Mine was replaced under the recall (at least I think that's what the recall was for) but this is still handy-dandy information to know, thanks Tim!
So, Charlotte (Concord?) to Greenville to Winston-Salem, huh? I've lived in all of those cities, but not in that order.
I'm in Cary now.
No, that has absolutely nothing to do with the topic, I just felt like sharing.
Old 04-29-2013, 02:49 PM
PCC
PCC's Avatar
It is but that doesn't do you much good if you're away for the weekend when it happens
Old 04-30-2013, 12:08 AM
gota911
gota911's Avatar
I'm in Cary now.
MJ,
Good memory! Yes, Concord, NC to Dallas, TX to Greenville, SC to Winston-Salem NC. Have go where the work is. Damn mergers and acquisitions!
I'm traveling from W-S to Greenville and back to W-S each weekend, which is getting old. We'll have to hook up some weekend, when we get moved to W-S.
Tim
Quick Reply: How to Override a Faulty Clutch Sensor
