DIY 997.1 Gear Oil Change
Old 11-16-2015, 01:06 PM
  #46
PelicanParts.com
Basic Sponsor
PelicanParts.com's Avatar
Very nice job.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old 12-30-2015, 07:17 PM
  #47
ymc226
ymc226's Avatar
Thank you for the great write up James. Very helpful as usual.
Can anyone confirm if the procedure is the same for a 2007 997.1 GT3? I've got 4 Jackpoint jack stands and getting into 1st gear seems a little notchy when cold (only at 20K miles but 8 years old) so I'm hoping a change to the Mobil 1 PTX will solve the problem.
Being new to working on my own cars, I'd like to know if the drain and fill plugs would look the same on the GT3. Wouldn't want to drain and fill the wrong holes:banged:
Old 12-30-2015, 07:26 PM
  #48
AWay
AWay's Avatar
I'd check in the GT3 specific section regarding your gearbox. We 'normal' 997 folk have Aisin 'boxes while you have a Getrag. Completely different units although I'd fathom that the process should be all but identical. Fill/drain holes could well be in different locations though.
Old 12-30-2015, 09:11 PM
  #49
USMC_DS1
USMC_DS1's Avatar
Lawrence, try ALLDATADiy.com. They have the basic tech pubs on the GT3. BTW, they don't have a search engine but these are the sub-folders/where I found the procedure for the 997.1. Maybe similar sub-folders within the GT3 pub. GL!
Vehicle » Transmission and Drivetrain » Manual Transmission/Transaxle » Fluid - M/T » Service and Repair » Procedures » Changing Transmission Oil
Old 12-31-2015, 12:49 AM
  #50
ymc226
ymc226's Avatar
Thanks James for the info and also for the Durametric recommendation. I ordered the Enthusiast first but may upgrade for the coding capability if I think I need it in the future.
Old 01-13-2016, 12:01 AM
  #51
Pors968
Pors968's Avatar
Default 997.2 gear oil change.
Is there a write up for 997.2 gear/tranny oil change? I searched and could not find.
Thanks,
Old 01-13-2016, 12:28 AM
  #52
lurchphil
lurchphil's Avatar
997.2 gear oil change is the same as the 997.1. Remove the rear under-panel. I think the two plugs are 24mm. Take the "fill" plug out first. (It's not good to drain the 75W90 and then not be able to remove the "fill" plug for obvious reasons.) Torque to about 25ft/lbs. Holds about 3 liters. Use the Mobilube PTX from Suncoast for the best shifting result. You can get a hand-pump at most auto parts stores.
Old 01-13-2016, 12:45 AM
  #53
Bruce In Philly
Bruce In Philly's Avatar
Received 1,429 Likes on 866 Posts
997.2 has two fill plugs, remove only the lower one.
Peace
Bruce on Philly
Old 01-13-2016, 12:52 AM
  #54
Pors968
Pors968's Avatar
Bruce- Two fill plugs? Is it similar to the pics posted in this thread?
Thanks,
Old 01-13-2016, 09:20 AM
  #55
Bruce In Philly
See here for 997.2 pics
Edit: http://www.renntech.org/forums/topic/48480-9972-transaxle-oil-and-capacity/
Peace
Bruce in Philly
Old 01-13-2016, 11:36 AM
  #56
Pors968
Pors968's Avatar
Peace
Bruce in Philly
Bruce - I don't see the pics. Is it a link?
Old 01-15-2016, 11:25 AM
  #57
BoomC2S
BoomC2S's Avatar
Just did mine yesterday. I did not have the transfer pump and this may have made things easier. Make sure you dive the car several miles to warm the fluid for easier draining.
I ordered 3 liters of Mobilube from Suncoast
Tools used were as described (t25, 10mm and 24mm)
The Renntech forum discusses a 16mm triple square and 17mm hex; however when I got under the car, this was not the case.
I have a scissor lift, so that kept the car level. I had to use an additional block to get better access to 2 t25 fasteners.
I did find some metal in the old fluid. I believe this is to be expected since the fluid had never been changed. Might be hard to see in the picture.
Not a difficult job to accomplish. I did notice a difference in shifting with the new fluid.
Old 05-30-2016, 10:17 PM
  #58
bommerts
bommerts's Avatar
Did this job today and went perfectly. Great write up, thanks!
Old 05-31-2016, 10:54 AM
  #59
candrtom
2nd Gear
candrtom's Avatar
I also completed this yesterday, and the shifting was noticeably smoother afterwards. Thanks for the write up, it made the job much easier.
CX750 (12-20-2020)
Old 06-18-2016, 08:21 PM
  #60
Backmarker
Backmarker's Avatar
I also did this one today, a couple of notes:
1 I only had to remove the rear most cover beneath the transmission, that gave me enough access.
2 I highly recommend removing the rear passenger wheel and coming at the car from the side. This will help you avoid having your entire torso under the engine, which makes me nervous as another poster also said
3 You can use the transfer pump to accelerate the draining process. Once you remove the fill bolt and the drain bolt, you can pump air into the transmission from the filler hole and this pushes out the remaining oil much faster as you essentially pressurize the transmission
4 It is very convenient to change the engine oil at the same time, adds maybe 30 minutes to the total time
I'm off for a test drive to see how different it feels!
Quick Reply: DIY 997.1 Gear Oil Change
