997 Mod Part 1: Deviated Front Seat Belts
Old 06-30-2013, 11:22 PM
USMC_DS1
USMC_DS1's Avatar
Default 997 Mod Part 1: Deviated Front Seat Belts
Background and Goals
My '08 C2S currently has 59.5K miles and 4.5+ yrs on the clock. I've been doing a few bolt on performance oriented mods since ownership 2.5 yrs ago and have been meaning to do a few more asthetic mods for the interior . This write-up will focus on the steps required to replace the stock front black seat belts with deviated guards red belts.
Note: contrary to popular belief... installing deviated guards red seat belts does not add 5-10 HP although it does make the car feel faster.
DIY Level
I consider this DIY project a level 2-3 out of 10. It's a fairly simple project to undertake. Here are some instructions and pics which may help others.
Time
1.5 -2 hrs... the second side only took about 30 minutes once I figured out the 1st side.
Caution/ Achtung!
Care should be taken to avoid disconnecting the front belts while the car is powered - connected to the battery. THE CAR BATTERY MUST BE DISCONNECTED AND SPECIFICALLY THE NEGATIVE GROUND TERMINAL SHOULD BE DISCONNECTED. Unlike the rear belts the front belts have an explosive charge which may discharge should it receive an electrical or even static discharge. I opened all doors and left the frunk opened as well to avoid any unnecessary issues with accessing the frunk and/or car with no power.
Tools Required:
- 10mm and 17mm sockets
- 6mm allen wrench or socket
- T20 torx socket
- 1/4" and 3/8" socket wrench
- torque wrenches (7.5 ft-lb and 37 ft-lb. capable)
- screw drivers… medium philips and a small flat head
- magnetic pickup tool
- interior panel/trim removal tool set
Optional Tools
- flash light
- boombox
- fan to fend off the 106*F Texas heat
Parts:
- a set of deviated seat belts. Color of your chosing: http://www.suncoastparts.com/product...ode=997S_Seats
Specifications:
- 7.5 ft-lb and 37 ft-lb
Instructions:
Disconnect the negative terminal from the car battery. Leave the frunk open.
Remove the coat hook bracket using one of the interior panel removal tools. Lift from the bottom out and up.
Pull the seat belt height adjuster plastic cover straight out. I placed my fingers behind it and applied force in a pulling motion away from the B pillar. I've heard that some were able to remove the unit as a whole but it came out in 3 pieces for me.
Size:  102.0 KBName:  P1020682.JPG
Size:  100.8 KBName:  P1020684.JPG
Remove the 17mm machine screw holding the seat belt guide onto the B pillar. (Use 37 ft-lb of torque when you reinstall this machine screw later). Now remove the philips screw holding B pillar trim in place then remove the B pillar trim piece by pulling it straight out
Size:  89.3 KBName:  P1020686.JPG
Size:  83.8 KBName:  P1020687.JPG
Remove the seat belt collar by pulling the rear most part of it up and the entire unit out. Note this is the driver side as I had a clearer pic of the rear tab. The rest of the pics are of the passenger side.
Size:  105.3 KBName:  P1020689.JPG
Remove the Philips screw holding the backseat side panel in place. Place a magnetic pickup tool next to the screw as you remove it to avoid having it fall down into the body panel.
irnnr (05-01-2020)
Old 06-30-2013, 11:40 PM
USMC_DS1
USMC_DS1's Avatar
Default 997 Mod Part 2: Deviated Front Seat Belts
Remove the rear seat locking pin with a 6mm allen. (Use 37 ft-lb of torque when you reinstall this allen screw later).
Now you're ready to remove the backseat side panel. Pull the side panel towards the center of the car starting with the top section… I started with the belt collar area. You'll hear it disconnect from the various tabs holding it in place.
Disconnect the speaker wires from the speaker. Then move it forward towards the front of the car and out.
Size:  98.0 KBName:  P1020696.JPG
Remove the plastic cap covering the bottom seat belt machine screw with the small flat headed screw driver. Remove the 17mm machine screw itself including the sleeve and note that the sleeve is between the end seat belt bracket and the body panel. (Use 37 ft-lb of torque when you reinstall this machine screw later).
Size:  99.3 KBName:  P1020692.JPG
Remove a 10mm screw from the seat belt deflector bracket. I left one screw on and loosen it enough to allow me to route the new belt through it the same way the old belt was routed. (Use 7.5 ft-lb of torque when you reinstall this machine screw later).
Size:  100.5 KBName:  P1020704.JPG
Remove the 17mm machine screw holding the seat belt tensioner mechanism. (Use 37 ft-lb of torque when you reinstall this machine screw later). Caution/ Achtung! THE CAR BATTERY MUST BE DISCONNECTED before you disconnect the electrical connection from the belt tensioner mechanism. Then remove the old belt tensioner body and belt from the car.
Size:  98.6 KBName:  P1020701.JPG
Size:  98.1 KBName:  P1020702.JPG
Execute the above process for both sides and use the reverse process to install the deviated belts.
After reconnecting the negative battery you'll notice that the windows may need to be reset. Just hold the button to row it up for 10 seconds and that should recalibrate it.
I also noticed some PSM CEL's when I started up the car. These cleared after I drove 1/2 a block.
maekwl (09-26-2022)
Old 06-30-2013, 11:50 PM
USMC_DS1
USMC_DS1's Avatar
Default The End Result: some eye candy
Size:  111.9 KB[ATTACH]Name:  P1020742.JPG
Size:  105.0 KB[/ATTACH]
The drive afterwards was enjoyable!
Next week the FVD g-red gauges faces will go in...
irnnr (04-02-2024)
Old 07-01-2013, 12:43 AM
malexgcab
malexgcab's Avatar
Very impressive
Old 07-01-2013, 12:47 AM
Robocop305
Robocop305's Avatar
Super, looking great!!
Old 07-01-2013, 02:16 AM
stronbl
stronbl's Avatar
Well written documentation as always and a great looking mod for your car!
Old 07-01-2013, 02:22 AM
Mspeedster
Mspeedster's Avatar
Looks awesome! Also, a great DIY write up with photos, thanks for posting!
Old 07-01-2013, 08:05 AM
Little Green
Little Green's Avatar
Excellent write up. Was looking to tackle this mod myself. Well done.
Old 07-01-2013, 08:34 AM
Jack667
Jack667's Avatar
Looks great. And great write-up! Really thorough which is extremely valuable to the community!
My black on black car has those belts, thanks to the original owner spec'ing them on his build. They are sharp!
Old 07-01-2013, 08:39 AM
rotesAuto
rotesAuto's Avatar
Location: North Carolina, '12 cls63 '14 S550V4, 07TT-gone, 07Targa4S-gone
aw man that's great! and sharing it all too!!!! respect!!!
this took some time to post too!
thumbs up sir!
Old 07-01-2013, 09:47 AM
cairo94507
cairo94507's Avatar
Nicely documented write-up. Thanks for the effort.
Old 07-01-2013, 12:12 PM
USMC_DS1
USMC_DS1's Avatar
Thanks folks... I'll have to admit that removing the 1st leather panel from the rear had a certain pucker factor to it. It was satisfying to discovered how well put together the car is and how nicely it all goes back together afterwards... No need to worry about a loose part creaking down the road. Here are a few more pics of the adjustable seat belt mechanism. I spent the most amount of time contemplating how best to disassemble and reassemble this part. Much easier than I made it out to be. It basically has 3 parts to it. Just make sure that each part is aligned properly into it's keyed position and everything will snap in properly. Once the whole unit is fitted back together make sure that the circular part of the assembly is aligned to fit over the 17mm bolt when you snap it back onto the B pillar.
GL with the project Simple Green. My car already feels faster after the MOD... JK.
Old 07-01-2013, 12:24 PM
iammulva
iammulva's Avatar
Did you mean "Little Green"? Too much time cleaning stuff in the corps?
Old 07-01-2013, 12:27 PM
USMC_DS1
USMC_DS1's Avatar
Haha... yes... what was that term in the Corps? Brain fart.
Old 07-01-2013, 12:38 PM
Little Green
Now that's funny. Simple Green. I am a simple man.
Quick Reply: 997 Mod Part 1: Deviated Front Seat Belts
