Air conditioning cuts out a little when accelerating
Old 07-25-2013, 09:25 PM
Gruson
Gruson's Avatar
Default Air conditioning cuts out a little when accelerating
Is it normal? If I push it hard, I can tell the AC does not blow as cold or as hard. Just curious. It seems to go back to normal a minute later if I stop driving hard.
Old 07-25-2013, 09:42 PM
WindyCityC2S
WindyCityC2S's Avatar
Normal.
Old 07-25-2013, 09:46 PM
CORSASCHNELL
CORSASCHNELL's Avatar
Yes all modern cars cut out AC on hard acceleration.
Old 07-26-2013, 11:32 AM
wwest
wwest's Avatar
NOT normal..
The compressor clutch circuit gets opened during WOT operations but that should NOT affect the blower speed. Let's suppose that what you're actually saying is that the airflow warms during hard driving periods. In that case if the engine cooling water jacket begins to climb toward overheating and then the compressor clutch circuit is opened to help with engine cooling. This latter even might be the result of failed condensor/radiator cooling fans.
Old 07-26-2013, 11:45 AM
7500rpm
7500rpm's Avatar
I want to believe most modern sport cars cut off the air cond compressor at WOT. I say this because driving my 911 with or without the air conditioner on doesn't appear to impact lap times too significantly. Would you believe the Ferrari Challenge cars keep their air conditioners in and I didn't notice significant difference in their lap times.
Old 07-26-2013, 11:49 AM
sixgun95
sixgun95's Avatar
Definitely not normal. Get it checked out.
Old 07-26-2013, 12:14 PM
USMC_DS1
USMC_DS1's Avatar
How long has it been since you changed the cabin air filter? May be a simple thing to check before looking into a more complex resolution. Here's a write up for both the .1 and .2 cars: https://rennlist.com/forums/997-foru...l#post10348842
Old 07-26-2013, 01:21 PM
Spiffyjiff
Spiffyjiff's Avatar
i was just going to chime in with this. frankly i'm not exactly sure one way or t'other re: this thread topic but i can say that the few times i have inadvertently left the AC on during a track session, i really havent noticed signif diff in lap times. (what...? it gets HOT on the grid, dagnabbit, but i simply forget to turn it off during pit-out!)
Old 07-26-2013, 02:22 PM
wwest
wwest's Avatar
Automotive A/C = 2 Tons = 24,000 BTU = ~10 HP.....no much adverse effect on a 300+ HP engine.
Pre-heated, condenser pre-heated, airflow for cooling that engine......
BIG effect..!!
Old 07-26-2013, 03:22 PM
Chaos
Chaos's Avatar
HiJack: Sometimes mine will go from cool to a little warm and musty for a few seconds and back to cool. Normal driving and the cabin filter has been changed.
Old 07-26-2013, 05:22 PM
GatorMD97
GatorMD97's Avatar
I just bought a 2011 Turbo S and I notice the same thing after WOT. Air is a bit warmer and humid for just a few seconds after and then returns to normal. I've only noticed it on some high speed runs though not just getting on it around town. Car only has about 1300 miles on it. I have to believe this is Normal.
Old 07-26-2013, 05:29 PM
Fahrer
Fahrer's Avatar
Basically all cars shut down the A/C compressor during WOT. In addition, with some cars, the loss of vacuum caused by the throttle being wide open can cause the vents in your dash to open or close if they are vacuum operated. Everything goes back to normal with moderate throttle. When I was a kid, my dad had a 1955 Chevy with vacuum operated windshield wipers. At WOT, the wipers came almost to a halt.
Old 08-17-2013, 10:45 PM
GatorMD97
GatorMD97's Avatar
Page 89 of my owners manual (2011 Turbo S) says that this is normal. Under the General Instructions for Air-Conditioning Compressor--"Can switch off briefly if engine is under an extreme load to ensure sufficient engine cooling"
Quick Reply: Air conditioning cuts out a little when accelerating
