Evap leak help!
Old 10-02-2013, 09:33 PM
Kschles
Kschles's Avatar
Default Evap leak help!
Hey everyone.
I have a cel throwing code p0455 which is a major evap leak. I already changed the gas cap, so that is not the issue.
Can anyone help me locate the evap vent hoses and evap cannister? Any help is greatly appreciated. I want to fix this shortly!
Thanks in advance!
Old 10-02-2013, 10:52 PM
neanicu
neanicu's Avatar
Check your purge valve. I don't know about Porsche,but in many cars that is the culprit if you can't find any leaks in the system. It usually makes a ticking noise after start up.
Old 10-03-2013, 10:52 AM
utkinpol
utkinpol's Avatar
I hate evap. on my lexus it is an ongoing problem and after $400 in replaced parts I gave up. father`s Honda started doing same, 2 way valve replaced, solenoid works, system seems to be ok but shows CEL once in a month and same does lexus, may be fine for 2 months then shows this error again. absolutely hate it, it is impossible to trace down...
Old 10-03-2013, 12:22 PM
douvillier
douvillier's Avatar
Take your car to a repair shop that will test for leaks with a smoke machine. The scan tool activates the purge valve and vent control valve to seal off the system and smoke is introduced thru the test port. Freeze frame data is recorded when a DTC code is set. Ensure that the EVAP leak is not set when the car is sitting. The EPA felt the test was not run enough so they mandated to run the test when the car is sitting shutdown after 30 mins or so. If you have a slightly weak battery the valves will not fully shut causing a leak. When you tighten the gas cap make sure you hear at least three clicks. Many of the components of the EVAP system are near the gas tank and therefore exposed to the elements, ensure that the powers and grounds are free of corrosion and damage. Good luck, repairing EVAP systems can be character developing and wallet deflating.
Old 10-03-2013, 03:03 PM
BIG smoke
BIG smoke's Avatar
Microsoft would recommend Ctrl/Alt/Del.
Disconnect battery for an hour?
I am not I.T. nor a mechanic.
Sadly this trick works with lots of devices, including my stove.
Old 10-03-2013, 03:17 PM
neanicu
neanicu's Avatar
Sound and complete advice. Mine was a short version. You should follow it! Hopefully you won't need to use a smoke machine since these cars are pretty new and shouldn't develop leaks so early,unless someone was in there. Also forgot to mention,the DME can identify a small leak from a large one. There's a different code for small leaks. Usually,cracked hoses or connections are identified as small leaks. Since you have a large leak,your best bets are gas cap or purge valve. Good luck!
Old 10-04-2013, 04:48 PM
joelpirela
joelpirela's Avatar
That could be:
Gas Cap
Evap Carbon Canister
Evap Purge valve (next to the TB on the engine)
Evap lines.
Most likely: Evap Purge valve (next to the TB on the engine)
Old 10-04-2013, 06:03 PM
utkinpol
utkinpol's Avatar
did it all on lexus, no leaks, no smoke shown from lines, stupid error still occurs from time to time, hate it.
Old 10-04-2013, 06:27 PM
Kschles
Kschles's Avatar
Thanks for all the help so far!
Old 11-19-2013, 10:18 PM
ebanks89
3rd Gear
ebanks89's Avatar
I have an 08 Cayenne gts and im getting the same p0455 code ive changed the gas cap done a smoke test, and had the leak detection pump replaced, code still comes on
Old 11-20-2013, 11:45 AM
fpb111
fpb111's Avatar
Might find some help here they talk about both valves.
https://rennlist.com/forums/996-foru...-996-help.html
Old 08-08-2016, 01:20 PM
Ibanezgod
Ibanezgod's Avatar
can anyone tell me where this valve is on an 07 turbo? I changed the gas cap and is still an issue. Just had the car in for engine out service, so curious if something got screwed up during the reinstall
Quick Reply: Evap leak help!
