How Much Oil Does Your Car Go Through?
Old 11-03-2013, 10:43 AM
yashagrawal
yashagrawal's Avatar
1 bar=0.4 L, for the genuine OCD's :-)
Old 11-03-2013, 10:50 AM
Fahrer
Fahrer's Avatar
My 2008 C2S uses oil at the rate of about quart per 5000 miles. I actually never add oil between changes ( every year/3500 miles). It's a weekend ride/garage queen.
I broke it in "by the book" as I do with all new cars.
Old 11-03-2013, 11:18 AM
Yet anothercrisis
Yet anothercrisis's Avatar
I have added 12 ounces in 10 thousand miles. Oil has been changed twice in that period which of course resets levels to full (if they were down, but not down enough to register on the electronic dipstick). The c2S was bought new in 2012.
Old 11-03-2013, 02:51 PM
Macster
Macster's Avatar
Originally Posted by Perk10
Hey everyone,
I have been going through quite a good amount of oil. My mechanic says it's completely normal to go through a quart of oil every couple thousand miles.
This sounds a little crazy to me but he is a Porsche tech. Am I missing something?
John
Your tech is right.
It can be perfectly normal for the engine to use a quart in under 1K miles, or to use no oil in 5K miles and anywhere in between. As long as the engine is operating with no untoward behavior, the CEL remains dark, there is no problem.
In the case the engine being reported as using no oil, what you have to consider is it is using oil.
But the accumulation of unburned gasoline and water (mainly water) is making up for the volume of lost oil. Short trips can really have the accumulation of unburned gasoline and water skyrocket, so to speak, in the engine oil.
(As an aside, I had my Boxster's engine oil analyzed shortly after I bought the car new and the water content was 7%. That's over 1/2 quart of water in the oil. My curiosity piqued I did some investigating and found out just how cold blooded these engines are.)
The flip side is the owner goes merrily along until one day he takes a nice long trip. Maybe gives the engine the whip a bit, too, during the trip.
The oil level drops. Sometimes drastically. All of the sudden the engine's an oil burner.
Well, not really.
What happened is the more volatile contaminates (unburned fuel and water) evaporated because the engine oil got nice and hot and remained hot for a while. The sudden drop in the oil level was the result of oil consumption over a number of miles that was highlighted by the loss of the other fluids that had been contaminating the oil.
The above is why I always discount claims of my engine uses no oil in xxxx miles and I am always willing to give the engine the benefit of the doubt when the owner claims the engine is an oil burner.
Also, how one uses the car, the engine, plays a role. Push the engine really hard, hard throttle, high rpms, and the oil consumption can go up, assuming there is no evaporation of unburned fuel and water from the oil. Or let the engine idle a lot, and this too can have oil consumption go up from its "normal" rate.
Last but not least for those engines that truly consume more oil I suspect the real culprit is a sub-par AOS rather than something inherently wrong or off in the engine.
The smoking at start up -- which we all see once in a while -- arises from the AOS and its failure to remove all (or enough) oil vapor from the crankcase fumes it routes to the intake. These fumes contact intake walls and oil condenses and collects. After the engine is shut off this oil warms up as the intake gains heat from the engine and the oil runs down into the engine.
If the AOS is not working right, or as efficiently as it should, it can let too much oil in the form of vapor past and into the intake where it is burned, most of the time the engine is running.
Since the engine is hot and the car moving one won't notice the oil being burned. That is there is none of the smoking one sees at cold engine start. But the engine uses oil, courtesy of the less than efficient AOS.
Old 11-03-2013, 03:26 PM
MessyMarvin
MessyMarvin's Avatar
I have had mine for almost a year, I have only done 1 oil change, so far it has not burned any oil. I put about 5k miles on it before the change and it was still full.
Old 11-03-2013, 06:05 PM
sandwedge
sandwedge's Avatar
Received 1,010 Likes on 718 Posts
About a quart every 2,000 miles. My -06 C4S used no oil at all.
Old 11-03-2013, 06:37 PM
slicky rick
slicky rick's Avatar
997.2 C2s, 25k km no oil addition in between oil changes. Regular 100km runs with occassional 200plus kph sprints. 4 years by march. But nowadays, takes a minute to measure oil level wherein before it only takes 4 to 5 seconds....something is starting to miss.
Old 11-03-2013, 09:51 PM
gabe2006
gabe2006's Avatar
997.1 C2 oil changed 3500mi ago and level did not drop since then. I'll change the oil before I need to add anything because it will be one year from last oil change (March).
Old 11-03-2013, 10:17 PM
Dadio
Dadio's Avatar
Variables that contribute to oil usage include short trips, multiple start stop cycles, driving style that keeps engine in the higher end of the rev band, etc... Owners manual states up to 1.6 qts per 622 miles is normal. This info can be found at the bottom of pg 328 and is the same for all 997 engines.
Old 11-03-2013, 11:10 PM
Perk10
Perk10's Avatar
Macster - awesome post. I forwarded to my tech and he enjoyed reading it.
To everyone else, I am glad to read that this is, in fact, a normal occurrence. I believe I am going through about a half a quart every 1,000-1,200 miles at this point but that is a rough estimate.
Old 11-03-2013, 11:20 PM
myw
myw's Avatar
that would be in line with me. every 2000 miles need to add almost 1 L
Old 11-03-2013, 11:44 PM
Perk10
Perk10's Avatar
Originally Posted by TommyV44
John……I have my car for 3 plus years and have never added oil! Now I know Dan (Edgy) adds oil all the time so I think it's the luck of the draw. I wouldn't worry about it.
On another note heading your way on Saturday for 3 weeks. I hope we can get together to check out your beauty. I'll shoot you an e-mail when I arrive.
All the Best,
Tom
Sounds great, Tom!
Old 11-04-2013, 05:31 AM
eljeffo64
eljeffo64's Avatar
My C2S is now almost eight years old, with me for seven years and currently on 42,000 kms - 25k miles; never uses a drop of oil, even after the occasional track day. Still in love after all this time :-)
Old 11-04-2013, 06:38 AM
Fahrer
Fahrer's Avatar
Another variable may be the accuracy of the system designed to check oil level.
Old 11-04-2013, 09:47 AM
Hatzenbach
Hatzenbach's Avatar
Originally Posted by okbarnett
3.8 DFI uses oil, like a 64 buick
Same here
Quick Reply: How Much Oil Does Your Car Go Through?
