Rear Tail Light Torque Screws?
Old 11-08-2013, 11:34 AM
atx.911
atx.911's Avatar
Default Rear Tail Light Torque Screws?
I have a 2006 997S and managed to lose two of the torx screws when putting in rear LEDs.
Anyone know where we can get replacement torque screws? They are the two that secure the rear tail light in place.
Old 11-08-2013, 11:37 AM
KeninBlaine
KeninBlaine's Avatar
Dealer?
Old 11-08-2013, 12:17 PM
Robocop305
Robocop305's Avatar
I need the same. I went to the dealer and they were having issues trying to find them for me.
Old 11-08-2013, 12:23 PM
jhbrennan
jhbrennan's Avatar
Item #5 ?? - if I can find it and read the diagram, you need to find a new dealer. Show him this page. If it's not item #5 then it's probably #4 which is the removable bracket that comes with two screws.
File Type: pdf
Old 11-08-2013, 12:48 PM
Robocop305
Robocop305's Avatar
I wander if 2008 have the same screws as 2009.
Old 11-08-2013, 12:49 PM
Robocop305
Robocop305's Avatar
BTW, thanks for posting the chart.
Old 11-08-2013, 02:03 PM
jhbrennan
jhbrennan's Avatar
Good point - they are different and I'm not as familiar with the 997.2 but here's the comparable parts page.
File Type: pdf
Old 11-08-2013, 04:42 PM
atx.911
atx.911's Avatar
Ditto thanks for posting the chart.
#4 points to the support mounting bracket. It is not the part.
#5 is not the part either. #5 is the screw (phillips head type screw) that attaches the mount bracket to the tail light housing (#1).
I found a similar but not exact torque screw at Lowes that comes close to fitting with some washers. It is a M5-.8 x 10MM. I wouldn't recommend using it though as you may strip your tail light housing.
Too bad the chart does not have the part number for torque screw they are showing in the chart facing the other direction. It may be the one we are looking for.
Old 11-08-2013, 04:47 PM
atx.911
atx.911's Avatar
Oh found it. That #4 is the right part, it does come with the torque screws. I ordered mine today. I spoke to a guy there and he confirmed it comes with the two torque screws you see in the pic.
AutoAtlanta Torque screw #4 part from diagram
Old 11-08-2013, 05:02 PM
jhbrennan
jhbrennan's Avatar
Different part numbers for right and left - make sure you ordered the correct side...or if you just need the screws, orientation won't matter.
Old 11-08-2013, 05:08 PM
atx.911
atx.911's Avatar
Thanks for the heads up! Yeah looks like I just paid $25 for torx screws!
Old 11-09-2013, 06:00 PM
kcheves
kcheves's Avatar
OP: You may want to edit the title of this thread to reflect that you are discussing Torx style machine screws, not torque values (force x distance) used to tighten the screw.
Old 11-09-2013, 06:57 PM
atx.911
atx.911's Avatar
Oh lol I think people may know what I'm talking about. I can't change the title. Maybe a moderator can? My bad.
Old 02-08-2016, 03:36 PM
archfarseer
archfarseer's Avatar
I've lost 2 Torx screws with the washers as well. One was lost with passing time and other when O'Reilly guy unscrewed one to match size (he gave a temporary m6 bolt).
Do you know the Torx screw size and dimensions? Thanks.
Old 02-08-2016, 09:43 PM
IslandS52
IslandS52's Avatar
If all these missing taillight torx screws are being lost because you (like me) are a clumsy oaf and managed to drop it down the little crevice and into the rear bumper...I have found that if you pull gently on the rear bottom of the bumper cover and flex it out a bit, the screw falls out the bottom.
Quick Reply: Rear Tail Light Torque Screws?
