Cleaning you engine...way to ... how to ...?
HI to everyone ... Bringing this to the forum... Please post your comments or DIY and photos
I understand that a clean engine performed better than a dirty one , looking for you to share your experience and wisdom
I would use P21s Total Auto Wash http://p21s.com/products/bis_taw.html or http://www.detailedimage.com/P21S-M1...000-ml-Kit-S1/ (since its safe for aluminum, rubber, wire harness, plastic, paint) use brushes and just a garden hose. No need for a pressure washer. if you have a air compressor blow out the water with air. Then use 303 http://www.detailedimage.com/303-M2/...-P12/16-oz-S1/ on all rubber and plastic parts. The engine will look like new!
The only thing that will make a engine perform better is a tune up. Spark plugs, new air cleaner and a high grade gas like shell. Cleaning an engine will not cause the engine to perform better.
I use a tooth brush and Simple Green, and then carefully rinse using my hose nozzle at a low volume rinse spray setting.
To keep my engine from getting dirt buildup, I detail it with a damp hand towel usually before I wash the car.
Never use simple green. It corrodes aluminum.
If you use Simple green you need to rinse, rinse, rinse, rinse! Simple Green will corrode aluminum, deteriorate rubber and plastic and stain paint if not rinsed well.
Correct. I think maybe OP is confusing cleaning the engine exterior with products or gasoline brands that claim to clean the engine's interior.
Even so, I like the engine to look reasonably clean. I just wipe down accessible areas with a bit of spray detailer on a rag.
