Replacement TPMS - Huf OEM or OE recommended
Old 04-15-2014, 04:15 PM
P-Nuts
P-Nuts's Avatar
Default Replacement TPMS - Huf OEM or OE recommended
Not a new topic, but trying to piece together from prior posts and my own research.
From earlier threads there seem to be three viable alternatives to the Porsche OEM parts: Which are best? Any comments appreciated. Thx.
Prices for a set of 4:
OE - $196 + $20 for black stems
OE by Titan - $161 in black
Huf OEM - $ 372 in black
The Titan run at 433Mhz and the Huf at 315MHz (not sure about the OE)
Any idea which are best ? They all claim to be compatible with my 06 C2S, does that mean both frequencies are recognized by the car? Confusing!
Here are the links:
http://www.titantpms.com/porsche-carrera-2006-2008
http://www.oewheelsllc.com/TPMS-Sens...2#.U016y8YXul5
Old 04-15-2014, 05:05 PM
chris.hanle
chris.hanle's Avatar
Not yet replaced mine. But many people say the OE work just fine for a lot less money. As far as 315 or 433Mhz, I think you have to make sure yours has xxx stem (alum, chrome, black), that will determine what your car can read. I haven't heard of our cars reading multiple frequencies. But again I have not yet changed mine in my p car.
Old 04-15-2014, 05:12 PM
P-Nuts
P-Nuts's Avatar
I was about to order the OE's then saw the frequency differences and that both claim to work with a 2006 911. Not sure how the stem color impacts the frequency, is that what you meant to say?
Old 04-15-2014, 11:29 PM
red carrera
red carrera's Avatar
Discount Tire did mine for 2008 C4S last month. $400-ish out the door. Reset within 5 miles of driving and showed same pressures as the OEM TPMS. I'm satisfied.
Old 04-16-2014, 09:45 AM
Misdirection
Misdirection's Avatar
As an additional data point, I got the OE TPMS stems for some track wheels and they are accurate, but they lose connection intermittently. Not sure if I just got duds or what.
Old 04-16-2014, 12:17 PM
997_Toronto
997_Toronto's Avatar
I just bought the Titan TPMS and they are being installed on my car as we speak (literally). I've not heard any negative feedback on these sensors.
Old 04-16-2014, 12:43 PM
Fahrer
Fahrer's Avatar
My understanding is that the OEM TPMS turn themselves off, to save the batteries, when the car is not moving. Do the after market devices do the same? If not it could mean an esarllier replacement time?
Old 04-16-2014, 12:53 PM
Banilej0
Banilej0's Avatar
Fahrer - I read that this is the case only for the 997.2 sensors, apparently there were TPMS improvements made in .2 and the sensors are not interchangeable with 997.1 (which don't turn off). Someone may be able to say for sure, not sure about the aftermarket ones.
Old 04-16-2014, 02:31 PM
Fahrer
Fahrer's Avatar
Perhaps it is not so critical, then. My 2008S is now over 5 years old and a recent Durametric reading indicates the TPMS batteries have 12 to 14 months of life left (I will be replacing the tires by then). All they need to do is last the life of the tires , as far as I am concerned. I wonder also if the aftermarket models will last as long. If so, it sounds like a good choice.
Old 04-16-2014, 03:25 PM
P-Nuts
P-Nuts's Avatar
Great timing !!! Let us know how you get on with them.
Still no thoughts on the frequencies ? 433MHz vs 315MHz.
Old 04-16-2014, 08:50 PM
997_Toronto
So...just picked up the car. I got the 433mhz as it was stated as the appropriate frequency for a 2007 C2. Started driving and warning came on stating "TPMS learning...". Within 10 minutes the warning disappeared and correct tire pressure was displayed.
Now it's a question of what happens over time but I'm positive things will be fine cause the start has been great (optimist...maybe, realist...probably).
Old 04-17-2014, 06:13 PM
P-Nuts
P-Nuts's Avatar
Great. Sounds like you are a happy camper. Good luck with your car….great color by the way :-)
Old 04-17-2014, 08:09 PM
997Austin
997Austin's Avatar
I purchased mine from OE wheels for $141 including shipping four months ago. Still working perfectly.
Old 04-19-2014, 12:36 AM
nzskater
nzskater's Avatar
To those that have gone with Titan/ITM/Oro Tek; do you need specific valve stems or will those that fit the OEM TPMS work? I replaced mine with black stems, relatively recently. Want to know if I need to buy more specifically for the new sensors.
Old 04-19-2014, 11:59 AM
fjasione997
fjasione997's Avatar
Valve stems came with the Titan sensors.
I believe you can order chrome or black.
Quick Reply: Replacement TPMS - Huf OEM or OE recommended
